Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: The RENESIS project RELEASED in 800x480
  1. #11
    Dec 2007
    very nice .. but mine is dark green.... maybe this will help..
    http://www.automobilemag.com/classif...585/index.html
    if you would, could you have it as "SinMan" instead of "Isuzu"... sinman is my nick name..
  2. #12
    Dec 2007
    gf-ler, i am having an issue getting ilist to work... IL tag that works on my prev skin, doesn't seem to work on this.. Could you help me sorting this out? Hope i am not bothering you too much..
  3. #13
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by brandensin View Post
    please have a look in iList working .skin file.
    is the iList in this skin a transparency one or did it use .bmp files for showing the textlines ? as i remember you need to install directx for showing transparency iLists...but dont beat me if iam wrong.
    also compare the values at the end of the command line. i use ....
    copy of the DIRECTION iList function in transparency mode
    /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed,
    IL,DL,RGBFF00FF,RGBFF00FF,,0,10,10
    perhaps the values at the end are too small for your system.
    the iList function only lost in one skin file...Audio_Browser2.skin....
    important....if you copy the commandline into the audio_browser2.skin, make sure its good to copy it in front of the DIRLIST command. and control the second command of it, IL,DL....DL means DirList.....IL,PL......means PlayList.
    did you load the opener file from post above ? is this car yours ? it was the best .jpg file i found in the web.
    here is the darkest green of your car i found. change a little bit the darkness by photoshop.
    Opener.rar
  4. #14
    Dec 2007
    I'll try your instruction today.. Yes i did try the opener.. Looks great, but my car color is dark green... no biggie.. i'll just use it... Thanks a lot for your help, GF-ler.
  1. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 11:11 AM
  2. FS: Lilliput 8" LCD w/ 2 Project Housings
    By migel628 in forum Classified Archive
    Last Post: 09-14-2005, 07:40 PM
  3. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
  4. Replies: 27
    Last Post: 12-10-2003, 07:36 PM
  5. More info on 800x480 mode for Xenarc...
    By InFix in forum LCD/Display
    Last Post: 08-27-2002, 09:54 AM
