Page 13 of 15 FirstFirst ... 3456789101112131415 LastLast
Results 121 to 130 of 142
Like Tree1Likes
Thread: 506 by DocBreezy with ws6vert's Garmin screen <<Beta Release>>
  1. #121
    Jul 2009
    Quote Originally Posted by treetop777 View Post
    Can you release your latest one with the dynamic buttons so we can play with it before you move to another project
    BTW - Nice animation in the flash version. Speaker icons look weird tho'
    +1 on this. They look like mini UFO's
  2. #122
    Low Bitrate docbreezy's Avatar
    Feb 2008
    Maryland
    could you also check on the RRMedia Database for me, i think i have everything configures right but still can't get it to work. can't add songs or playlists to disk and the sort. I posted help in the RRmedia thread but it seams my posts are invisible.
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  3. #123
    Feb 2008
    Maryland
    Quote Originally Posted by ihateafropaul View Post
    Lol, i hear y'all. Its a work in progress, but like i said its a while before i put some serious work on this so we'll see what i come up with then.
    And damn i thought those wre pretty originally nice.lol
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  4. #124
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by docbreezy View Post
    Here is what i have so far for the dynamic button version. Pls pay attention to the Please Read Me file to set correct paths as i just pull this out of my skins folder and didn't clean it up.
    I didn't mean to stray from current business, i have a little bit of attention deficit lol. But no fear i have to get this skin done and stable before i turn it to flash.
    P.S. i know the Volume buttons are different but again i wanted icons of my own and that is what i came up with thus far.
    Thanks for sharing but after taking a look at it's guts - i'm lost! maybe cause some aspects are modeled after Carputer1's unorthodox way of coding.
    Thought i could help finish it but now i don't think so.
    Again, thanks for sharing.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  5. #125
    Feb 2008
    Maryland
    Lol, you see what i released it yet though, all the codes are right but its just non-compliant. Thanks for looking though. Did you by any change check the RRMedia, to see if you can add songs and playlists to disk?
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  6. #126
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Thats 1 way of putting it lol....
    just dl'ed the attached files with dynamic buttons works well
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  7. #127
    Feb 2008
    Maryland
    Dit it work as is or did you have to modify something? if not then we can only assume it is something system specific. Eitherway i will study some of the other skins with dynamic button to see what solution i can come up with.
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  8. #128
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    If iremember right the buttons changed straight off the only
    Mod I did was set the path for imageviewer. I'll download
    Again here at work and try it again give me an hour
  9. #129
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Ok tested again , thebutton swap works good but not all buttons
    Work after change. Like settings button , YouTube works as does video
    I'll into it later for you, I think it's just the launch cmd for
    Those buttons, nothing to drastic
  10. #130
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok doc found your problem its your exectbl lines for launching the cmds you use for the menu.
    ie = settings , in exectbl you have this
    "SETTINGS","MENU;Settings.skin","" Remove the last 2 "" then it will work
    "BPICS"Load;Photo.skin;Imageviewer;Support\Imagevi ewer\Imageviewer.exe;Imageveiwer",""
    2 things wrong here, again with the extra "" and you have not defined the path for the exe in the launch line, if imageviewer is in your skin folder like the line looks to suggest then your launch line should be like this
    "BPICS"Load;Photo.skin;Imageviewer;$SKINPATH$Support\Imageviewer\Imageviewer.exe;Imageveiwer"
    hope this helps , may need to check the rest of your code, i have only got time to check these 2 lines as trying to put my truck dash board back in after my heat matrix blew on me and i'm off on holiday tommorrow..
    sorry i can't help more
  1. Centrafuse Beta 1.40
    By veetid in forum Centrafuse
    Last Post: 11-12-2007, 10:29 AM
  2. laptop wont keep vid settings / Non dock compatable to use with doc??
    By hombredelassrta in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-24-2005, 11:50 PM
  3. Replies: 0
    Last Post: 12-22-2005, 10:46 AM
  4. Infiniti G35, 7" Xenarc Install, How-To Doc
    By god_of_cpu in forum LCD/Display
    Last Post: 02-20-2004, 03:03 PM
  5. Telxon PTC w/ DOC and WiFi
    By Hyp3rion in forum Newbie
    Last Post: 01-14-2004, 11:56 AM
