Page 4 of 14 FirstFirst 12345678910111213 ... LastLast
Results 31 to 40 of 140
Thread: 506 by DocBreezy with ws6vert's Garmin screen <<Beta Release>>
  1. #31
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    Doc!
    Nice skin, as I wrote you in another thread, the new coverjuke plugin is posted in the plugins section. If you use it, let me know if you need any support with it.
  2. #32
  3. #33
    Low Bitrate docbreezy's Avatar
    Feb 2008
    Maryland
    Quote Originally Posted by ws6vert View Post
    Doc!
    I'm on if, already got this set up and working great. I have this set up as my default Cover Browser. The wife usually gives me a nod of encouragement but she usually not that interested in what i'm doing. When i showed her this screen, she actually "Wowed" it and approved its addition. She even played with it for a while. Great find, and Good job integrating in RR.
    Quote Originally Posted by pcpete View Post
    The most stylish and consistent skin! Love it...
    Thanks Man, Trying something.
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  4. #34
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    i also give my vote to make this skin as RR's default skin.
  5. #35
    Feb 2008
    Maryland
    Well i spent some time trying to figure a way to add dynamic menu buttons. The main menu isn't going to be dynamic, but in the spirit of customization, the two alternate menus will be. I personnaly won't need then, but i know everyone uses different Apps. Anyway some held hooking up these dynamic buttons will be appreciated.
    Also the following is the alternate screen i will be using for the two other menus, since i use icons and no text, can i load the glass image over the set icon to get the desired effect? and if so, what dictates in which order the images will display?
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  6. #36
    Sep 2008
    Baton Rouge
    how is it coming doc?
  7. #37
    Jan 2009
    wow this skin is by far the best i've seen cant wait til your done with it
  8. #38
    Feb 2008
    Maryland
    My bwoy. Well its coming along, slower that expected because i have to do "alot" of trial and error in order to get the codes working but im getting it done. I got your update, and as expected, flawless.
    Quote Originally Posted by qfour5 View Post
    Not too long before its done, no timetable. A few major parts left, but mostly little bits and pieces. I'm trying to make everything work as perfectly as possible because chances are if there are any bugs in the codes, i will be as lost as you.
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  9. #39
    Variable Bitrate jthiani's Avatar
    May 2005
    Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
    love your work. i will be using this skin in my z at some point.
  10. #40
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    [QUOTE=docbreezy;1295163]Well i spent some time trying to figure a way to add dynamic menu buttons. The main menu isn't going to be dynamic, but in the spirit of customization, the two alternate menus will be. I personnaly won't need then, but i know everyone uses different Apps. Anyway some held hooking up these dynamic buttons will be appreciated.
    [QUOTE]
    For changeable dynamic buttons, use a variable for your button code.
    LIKE THIS
    "$BUTTONCOMMAND1$"
    This will use variable BUTTONCOMMAND1 as your command setting
    You can set the variable using a setvar command and a save it using a savetoskin command. I did this in one of my earlier skins. You could also write a script that would save it to a specific section of your skin.ini alon with setting a label code and image file for use as an icon.
    I attached a script I made real quick to help with creating these buttons
    You will need to make sure you have an OSK for your skin and Voices enabled
    have fun, read the readme.txt
    Go to this thread for the download
    New Age Garmin - Skin for RR
  1. Centrafuse Beta 1.40
    By veetid in forum Centrafuse
    Last Post: 11-12-2007, 10:29 AM
  2. laptop wont keep vid settings / Non dock compatable to use with doc??
    By hombredelassrta in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-24-2005, 11:50 PM
  3. Replies: 0
    Last Post: 12-22-2005, 10:46 AM
  4. Infiniti G35, 7" Xenarc Install, How-To Doc
    By god_of_cpu in forum LCD/Display
    Last Post: 02-20-2004, 03:03 PM
  5. Telxon PTC w/ DOC and WiFi
    By Hyp3rion in forum Newbie
    Last Post: 01-14-2004, 11:56 AM
