do you have usedx=false in rr.ini or skin.ini ?
I have the following definied in my .skin file
And all I get is a normal looking directory list, that I cannot scroll. Any suggestions?Code:/,iList Support SD,00,03,,,"$COVERJUKEPATH$",".mp3.wav.wma.aac.m4a",False IL,DL,RGBFF00FF,RGBFF00FF,,1,30,70 S02,209,111,380,213,,,,,,,0,0,0,0,0,0,0,0,0,#FONTTHEMER#,#FONTTHEMEG#,#FONTTHRMEB#,true,15,"HandelGotD"
Ride Runner RR's Myspace
rr.ini has usedx=true. Should it be false?
should be true... do you have directx 7 installed and have you tried other skins with iList to make sure it works on your machine ?
actually I think I have Directx 10 installed or somewhere around that number. I'll check a different skin when I get back to home computer.
checked with a different skin, and still a no go. Is anyone else having problem with Ilists?
can you make a debug log ? which skin did you try (many skins don't have ilists) ?
I am posted earlier this morning
New Age Garmin - Skin for RR
HA, the skin I tried was New Age- Garmin
