Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: OSKTOCMD problem - solved
  1. #11
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    The way coverjuke is embedded, you cannot send a direct keystroke to it. So using RR's sendkey will do nothing but stare back at you. So I wrote CJSend to send the keys directly to coverjuke when it has been embedded.
    Secondly, I was unable to send just R to coverjuke and have it understand. I will retry the issue, but using AutoIT, I had to send the commands with {} for coverjuke to perform the operation. I will look back into it, but this was my reasoning. I will also try the double pipes. The source code for CJSend is in the download, if you wanted to have a look at it.
  2. #12
    Sep 2008
    Baton Rouge
    Here is the real question, why would RR Skin Tool be able to perform the command correctly, but using the command in a button on the skin will not execute the command?
    Edit:
    Adding "||" to the beginning fixes the issue. Thank you El Camino
  3. #13
    Nov 2008
    "{$GOTOALBUM","||OSKTOCMD;CJ_LETTER;RUN;$skinpathh $CJSend.exe {$CJ_LETTER
    not worrking for me....
  4. #14
    Sep 2008
    Baton Rouge
    The above command is a little off:
    it should look like:
    Code:
    "GOTOALBUM","||OSKTOCMD;CJ_LETTER;RUN;$skinpath$CJSend.exe|{$CJ_LETTER$}"
    or you can make the Run command its own command, such as:
    Code:
    "GOTOALBUM","||OSKTOCMD;CJ_LETTER;SKIPTOLETTER"
    "SKIPTOLETTER","RUN;$skinpath$CJSend.exe|{$CJ_LETTER$}"
    These commands should be placed in your execTBL.ini
  5. #15
    Nov 2008
    so i need to put two commands on one button (GOTOALBUM+SKIPTOLETTER)?
  6. #16
    Sep 2008
    Baton Rouge
    add the code above to your execTBL.ini. Make sure you remove your old GOTOALBUM command
    You will only need to add GOTOALBUM to the button
  7. #17
    Nov 2008
    ok the OSK is open but it did not do a search
  8. #18
    Nov 2008
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
