Results 1 to 10 of 18
Thread: OSKTOCMD problem - solved
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    I have the following command for a button in my skin:
    Code:
    "OSKTOCMD;CJ_LETTER;SKIPTOLETTER"
    and in my execTBL:
    Code:
    "SKIPTOLETTER","RUN;$pluginspath$CJSend.exe|{$CJ_LETTER$}"
    For some reason, SKIPTOLETTER is not being executed when I click Enter in the OSK.
    Even more strange, If I use the RR SKin Tool to pass the button command, it will work, and SKIPTOLETTER is executed.
    Any ideas? Any others with this issue?
    Edit:
    Adding "||" to the beginning of the command, makes it work correctly.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by ws6vert View Post
    Code:
    and in my execTBL:
    Code:
    "SKIPTOLETTER";"RUN;$pluginspath$CJSend.exe|{$CJ_LETTER$}"
    Typo.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Sep 2008
    Baton Rouge
    Quote Originally Posted by Sal R. View Post
    Typo.
    Typo is with the post, my bad. I have it correct in ExecTBL and it still does not work.
    -I have determined that using the button command will not save the value to CJ_LETTER, when I call the exact same command in RR Skin Tool, it will save the value to CJ_LETTER and execute SKIPTOLETTER. I can not figure out why this is?
    Sep 2008
    Baton Rouge
    Here is relevant information from debug log. The first time, OSKTOCMD is run is using the button in skin. The second is using RR Skin Tool:
    Code:
    2/26/2009 6:05:28 PM: Enter Exec: False, coverjuke.skin, "ONBTNPRESS||GOTOALBUM", False
    2/26/2009 6:05:28 PM: Que Exec: True, coverjuke.skin, "ONBTNPRESS||GOTOALBUM", False
    2/26/2009 6:05:28 PM: Executing: ONBTNPRESS
    2/26/2009 6:05:28 PM: Que Exec: True, coverjuke.skin, "GOTOALBUM", False
    2/26/2009 6:05:28 PM: Executing: OSKTOCMD;CJ_LETTER;SKIPTOLETTER
    2/26/2009 6:05:29 PM: Que Exec: True, osk.skin, "ONSCREENCHANGE", False
    2/26/2009 6:05:29 PM: Executing: ONSCREENCHANGE
    2/26/2009 6:05:29 PM: Leave Exec: False, osk.skin, ONSCREENCHANGE, False
    2/26/2009 6:05:33 PM: Enter Exec: False, osk.skin, "ONBTNPRESS||r", False
    2/26/2009 6:05:33 PM: Que Exec: True, osk.skin, "ONBTNPRESS||r", False
    2/26/2009 6:05:33 PM: Executing: ONBTNPRESS
    2/26/2009 6:05:33 PM: Que Exec: True, osk.skin, "r", False
    2/26/2009 6:05:33 PM: Executing: r
    2/26/2009 6:05:33 PM: Command not executed: r
    2/26/2009 6:05:33 PM: Que Exec: True, osk.skin, "ONCOMMANDINVALID", False
    2/26/2009 6:05:34 PM: Executing: ONCOMMANDINVALID
    2/26/2009 6:05:34 PM: Leave Exec: False, osk.skin, ONCOMMANDINVALID, False
    2/26/2009 6:05:35 PM: Enter Exec: False, osk.skin, "ONBTNPRESS||ENTER", False
    2/26/2009 6:05:35 PM: Que Exec: True, osk.skin, "ONBTNPRESS||ENTER", False
    2/26/2009 6:05:35 PM: Executing: ONBTNPRESS
    2/26/2009 6:05:35 PM: Que Exec: True, osk.skin, "ENTER", False
    2/26/2009 6:05:36 PM: Executing: ENTER
    2/26/2009 6:05:36 PM: CheckResume: ResumeMusic=2 WasRadio=0
    2/26/2009 6:05:36 PM: Enter Exec: True, coverjuke.skin, , False
    2/26/2009 6:05:36 PM: Que Exec: True, coverjuke.skin, "ONSCREENCHANGE", False
    2/26/2009 6:05:36 PM: Executing: ONSCREENCHANGE
    2/26/2009 6:05:36 PM: Leave Exec: False, coverjuke.skin, ONSCREENCHANGE, False
    2/26/2009 6:05:56 PM: Enter Exec: False, coverjuke.skin, , False
    2/26/2009 6:05:57 PM: Que Exec: True, coverjuke.skin, "OSKTOCMD;CJ_LETTER;SKIPTOLETTER", False
    2/26/2009 6:05:57 PM: Executing: OSKTOCMD;CJ_LETTER;SKIPTOLETTER
    2/26/2009 6:05:57 PM: Enter Exec: True, osk.skin, , False
    2/26/2009 6:05:57 PM: Que Exec: True, osk.skin, "ONSCREENCHANGE", False
    2/26/2009 6:05:57 PM: Executing: ONSCREENCHANGE
    2/26/2009 6:05:57 PM: Leave Exec: False, osk.skin, ONSCREENCHANGE, False
    2/26/2009 6:05:58 PM: Enter Exec: False, osk.skin, "ONBTNPRESS||r", False
    2/26/2009 6:05:58 PM: Que Exec: True, osk.skin, "ONBTNPRESS||r", False
    2/26/2009 6:05:58 PM: Executing: ONBTNPRESS
    2/26/2009 6:05:58 PM: Que Exec: True, osk.skin, "r", False
    2/26/2009 6:05:58 PM: Executing: r
    2/26/2009 6:05:58 PM: Command not executed: r
    2/26/2009 6:05:58 PM: Que Exec: True, osk.skin, "ONCOMMANDINVALID", False
    2/26/2009 6:05:58 PM: Executing: ONCOMMANDINVALID
    2/26/2009 6:05:58 PM: Leave Exec: False, osk.skin, ONCOMMANDINVALID, False
    2/26/2009 6:06:00 PM: Enter Exec: False, osk.skin, "ONBTNPRESS||ENTER", False
    2/26/2009 6:06:00 PM: Que Exec: True, osk.skin, "ONBTNPRESS||ENTER", False
    2/26/2009 6:06:00 PM: Executing: ONBTNPRESS
    2/26/2009 6:06:00 PM: Que Exec: True, osk.skin, "ENTER", False
    2/26/2009 6:06:00 PM: Executing: ENTER
    2/26/2009 6:06:00 PM: CheckResume: ResumeMusic=2 WasRadio=0
    2/26/2009 6:06:00 PM: Enter Exec: True, coverjuke.skin, , False
    2/26/2009 6:06:01 PM: Que Exec: True, coverjuke.skin, "ONSCREENCHANGE", False
    2/26/2009 6:06:01 PM: Executing: ONSCREENCHANGE
    2/26/2009 6:06:01 PM: Que Exec: True, coverjuke.skin, "SKIPTOLETTER", False
    2/26/2009 6:06:01 PM: Executing: RUNQ;C:\Program Files\RideRunner\Plugins\CJSend.exe|{r}
    2/26/2009 6:06:01 PM: Shell: "C:\Program Files\RideRunner\Plugins\CJSend.exe" {r}
    2/26/2009 6:06:01 PM: Leave Exec: False, coverjuke.skin, RUNQ;C:\Program Files\RideRunner\Plugins\CJSend.exe|{r}, False
    As you can see, the first time the command is used, the SKIPTOLETTER is not executed. The second time using RR Skin Tool, it is executed.
    Aug 2006
    Sun Diego
    Any chance "SKIPTOLETTER" is defined in another part of ExecTBL?
    Sep 2008
    Baton Rouge
    no, my execTBL is pretty basic unlike others cough:MITCH:cough; I might reinstall RR tonight and see if that fixes the issue. Has anyone tried this, and had the same problem?
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    You probably mean CHUCK!
    Sep 2008
    Baton Rouge
    Yeh, Chuck... Either way im sure Mitch's is ridiculous too.
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    try it like this, (include the double pipes)
    Code:
    "||OSKTOCMD;CJ_LETTER;JUMPTOLETTER"
    if you want to send letter "R" coverjuke is getting "{R}" the way you have it, and you need to send "R" only
    no"{}"
    Code:
    "JUMPTOLETTER","RUN;$pluginspath$CJSend.exe|$CJ_LETTER$"
    also, is always a good idea to run scripts from the source when testing.
    QUESTION:
    why you need a script to send a KEY to coverjuke, you can do that with pure RR code.
    Low Bitrate docbreezy's Avatar
    Feb 2008
    Maryland
    That worked for me. Coverflow is complete for me. i couldn't ask for anything more
    506 Skin
    506 Flash!
    NEVER BLEND IN!!!
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
