RR only does that when 'browsing' directories, so when you are in audio_browser skin ,my ilist should scroll sideways, it does on my pc...
Printable View
Ahhh.. yep.. got it to work. The drag direction is around the wrong way though :p.
I read somewhere there is a way to change drag direction (altho that might have been for Coverjuke or something). Can I reverse the drag direction on this? It feels counter-intuitive to me.
I'm happy to test your next release when available. :)
Yep, there sure is cause I thought the exact same, was always going the wrong way...hehe
Setting is on the...General>Pg3 bottom of the march release config. Ilist swap L/R
Cheers mate...
FYI , I released a test version of the flash album viewer shown above in the plugins forum... here's the link...
It's called CD Mess :)
http://www.mp3car.com/vbulletin/rr-p...-eyecandy.html
thanks.
just checked it out.. very nice!
I am trying to add a Indicator to one of your flash buttons except the indicator name is RM_1STAR and being how your flash buttons use _ to seperate each command in the name, I don't know how to correct this.
Is there a way to sub a inidcator variable with another so I can rename it to something like RM1Star?
Or is there a way to type in the value in the flash button name with the _ and still work?
I trying to make 5 buttons with 1-5 stars selection using your flash buttons and if the indicator is true also change the color of the buttons to know what the rating is without needing seperate indicators on my screen. A nice all in one button and indicator type deal.
BTW PCPETE not sure why your flash buttons don't get a lot of exposure and more screens shots of people's creations using it. It is very nice and sweet and I use purely your flash files for my skin.
Thx, glad to see someone using them!!
Not sure if it is possible , can you elaborate some more , possibly with screenshots, exactly what you are trying to do?
I am using RR_Media + plugin. RR_media has some already define Indicator values RM_1Star,RM_2Star,RM_3Star..etc. The value is true or false and this is used to light up the star indicator for ratings.
This is my button file.
RFB1_Star_Star_1_Star1_18^Arial_Narrow^0xFFFFFF^Le ft_xx_xx~RM_1STAR`True`xx_xx_xx_xx_0x00ff00_xx&RM_ 1STAR`False`xx_xx_xx_xx_0xff0000_xx.swf
As you can see the ~RM_1STAR in the file name wont work because of the _. Is there a way around this or is there a way to declare a new Indicator variable using the value from RM_1Star so I can call it something else like RM1STAR to be used with your buttons?
Here some pix off topic With your Flash buttons skin
Cool sceenshots!! I was wondering if anyone was using them...
I see the problem now , yes the underscore will screw things up...I don't know if you can redefine, or otherwise re-address indicators via an exectbl command, I think can modify the component to handle underscores by either using a seperate character, let me look into it...
Actually, I just tried (in my code) with underscore in the indicator field , and it seems to work...
Are you including the indicator you are monitoring in you skin...like this e.g.
I,0,0,0,0,"RM_1STAR",
