Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Error: The requested action with this object has failed.
  1. #11
    Aug 2004
    Germany
    Compiled AutoIt scripts always say "line -1", when an error occurs.
    AutoIt scripts communicate with RoadRunner/RideRunner by creating a so-called object.
    If RR isn't running the object is invalid, which leads to your error message.
    This can happen when:
    -RR isn't running
    -you quit RR and the script still tries to communicate with it
  2. #12
    Newbie nWoJester's Avatar
    Dec 2008
    Illinois
    Well thats the thing that is confusing. The plugin is starting using the "onstart..." command in the "exec..." file. This must be starting to fast and not noticing the RR is running. Maybe I should try opening it manually after RR starts.
  3. #13
    Aug 2004
    Germany
    Could be that the script is not just creating a RR object. Running it manually after RR is started is worth a try...
  4. #14
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    latest wifi script has this issue fixed, the one included in DFX was a mod done by john, using my source, i'm working(slowly) in a better version, which uses windows wlan api dll, xpsp2, xpsp3 and vista have this dll, so maybe W7 will be supported as well, no need to embed windows wireless network window, all will be skinnable.
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. Centrafuse 1.42 Update
    By veetid in forum Centrafuse
    Last Post: 11-25-2007, 04:41 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Replies: 7
    Last Post: 07-01-2005, 04:29 PM
  5. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
