opps. I should have mentioned that I know it is related to the skin because if I load a different skin the error doesn't occur.
I am getting the error in the above error when I launch ride runner using the DigitalFX 4.0 skin. The title of the error box is "AutoIt Error" so it is coming from one of the many, many scripts that are included with DFX 4.0. Is there anyway to find out which script is causing the error? I looked through the debug.txt from RR but I don't see anything. Posting it here in case it is relevant.
5/1/2009 11:58:14 AM: Start -- Version: 4/18/2009
5/1/2009 11:58:14 AM: OS Type: XP
5/1/2009 11:58:14 AM: FileManager: FileMode = Legacy
5/1/2009 11:58:14 AM: FileManager: mypath = C:\Program Files\Road Runner\
5/1/2009 11:58:14 AM: FileManager: ProfilePath = C:\Documents and Settings\Main\My Documents\RideRunner\
5/1/2009 11:58:14 AM: Master Vol: Master Volume/4
5/1/2009 11:58:14 AM: GetLineControl Failed: 401
5/1/2009 11:58:14 AM: No Treble Support
5/1/2009 11:58:14 AM: No Bass Support
5/1/2009 11:58:14 AM: Source: Wave=&H1008/1
5/1/2009 11:58:14 AM: Source: SW Synth=&H1004/2
5/1/2009 11:58:14 AM: Source: 3D Depth=&H100A/3
5/1/2009 11:58:14 AM: No Mute for Source
5/1/2009 11:58:14 AM: Source: Mic=&H1003/4
5/1/2009 11:58:14 AM: Source: Line In=&H1002/5
5/1/2009 11:58:14 AM: Source: CD Player=&H1005/6
5/1/2009 11:58:14 AM: Source: Video=&H100A/7
5/1/2009 11:58:14 AM: Source: Aux=&H100A/8
5/1/2009 11:58:14 AM: Source: Phone=&H1006/9
5/1/2009 11:58:14 AM: Source: PC Speaker=&H100A/10
5/1/2009 11:58:14 AM: Source: Wave=&H1008/11
5/1/2009 11:58:14 AM: Can't Open Source
5/1/2009 11:58:16 AM: PLAYER: Winamp Version: 5.03
5/1/2009 11:58:16 AM: No Phidgets interface detected.
5/1/2009 11:58:16 AM: Plugin Manager: loading Global Plugins...
5/1/2009 11:58:17 AM: Plugin Manager: Plugin Found: MobilePhone(.NET)
5/1/2009 11:58:17 AM: Plugin Manager: Warning Plugin MobilePhone does not support Initialize Method
5/1/2009 11:58:17 AM: Plugin Manager: Plugin loaded (Global): MobilePhone
5/1/2009 11:58:17 AM: Plugin Manager: Plugin Found: RRExtended
5/1/2009 11:58:17 AM: Plugin Manager: Warning Plugin RRExtended does not support Enabled Method
5/1/2009 11:58:17 AM: Plugin Manager: Warning Plugin RRExtended does not support Initialize Method
5/1/2009 11:58:17 AM: Plugin Manager: Plugin loaded (Global): RRExtended
5/1/2009 11:58:17 AM: Plugin Manager: loading Global Plugins Completed.
5/1/2009 11:58:17 AM: LoadSkin: C:\Program Files\Road Runner\Skins\DigitalFX 4.0\
5/1/2009 11:58:17 AM: Plugin Manager: loading SkinDir Plugins...
5/1/2009 11:58:17 AM: Plugin Manager: loading SkinDir Plugins Completed.
5/1/2009 11:58:19 AM: Plugin Manager: Warning Plugin RRMEDIADB does not support Enabled Method
5/1/2009 11:58:19 AM: Plugin Manager: Warning Plugin RRMEDIADB does not support Initialize Method
5/1/2009 11:58:19 AM: Plugin Manager: Plugin loaded (menu.skin): RRMEDIADB
5/1/2009 11:58:19 AM: Plugin Manager: Warning Plugin SKINTOOL does not support Enabled Method
5/1/2009 11:58:19 AM: Plugin Manager: Warning Plugin SKINTOOL does not support Initialize Method
5/1/2009 11:58:19 AM: Plugin Manager: Plugin loaded (menu.skin): SKINTOOL
5/1/2009 11:58:19 AM: Plugin Manager: Warning loading mobilephone (Attempt load more then once, most likely duped in globals and/or in skin).
5/1/2009 11:58:23 AM: CheckResume: ResumeMusic=1 WasRadio=0
5/1/2009 11:58:24 AM: Enter Exec: False, menu.skin, , False
5/1/2009 11:58:24 AM: Que Exec: True, menu.skin, "SETVAR;SKINORIGWIDTH;800||SETVAR;SKINORIGHEIGHT;6 00||SETVAR;SKINSHOWWIDTH;720||SETVAR;SKINSHOWHEIGH T;480||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITIO N;0", False
5/1/2009 11:58:24 AM: Executing: SETVAR;SKINORIGWIDTH;800
5/1/2009 11:58:24 AM: Que Exec: True, menu.skin, "SETVAR;SKINORIGHEIGHT;600||SETVAR;SKINSHOWWIDTH;7 20||SETVAR;SKINSHOWHEIGHT;480||SETVAR;SKINXPOSITIO N;0||SETVAR;SKINYPOSITION;0", False
5/1/2009 11:58:24 AM: Executing: SETVAR;SKINORIGHEIGHT;600
5/1/2009 11:58:24 AM: Que Exec: True, menu.skin, "SETVAR;SKINSHOWWIDTH;720||SETVAR;SKINSHOWHEIGHT;4 80||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0 ", False
5/1/2009 11:58:24 AM: Executing: SETVAR;SKINSHOWWIDTH;720
5/1/2009 11:58:24 AM: Que Exec: True, menu.skin, "SETVAR;SKINSHOWHEIGHT;480||SETVAR;SKINXPOSITION;0 ||SETVAR;SKINYPOSITION;0", False
5/1/2009 11:58:24 AM: Executing: SETVAR;SKINSHOWHEIGHT;480
5/1/2009 11:58:24 AM: Que Exec: True, menu.skin, "SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION; 0", False
5/1/2009 11:58:24 AM: Executing: SETVAR;SKINXPOSITION;0
5/1/2009 11:58:24 AM: Que Exec: True, menu.skin, "SETVAR;SKINYPOSITION;0", False
5/1/2009 11:58:24 AM: Executing: SETVAR;SKINYPOSITION;0
5/1/2009 11:58:24 AM: Que Exec: True, menu.skin, ONLINE, False
5/1/2009 11:58:24 AM: Executing: NLIN
5/1/2009 11:58:24 AM: Leave Exec: False, menu.skin, NLIN, False
5/1/2009 11:58:25 AM: Enter Exec: False, menu.skin, , False
5/1/2009 11:58:25 AM: Que Exec: True, menu.skin, "ONSONGSTART", False
5/1/2009 11:58:25 AM: Executing: RM_ONSONGSTART
5/1/2009 11:58:25 AM: Command not executed: RM_ONSONGSTART
5/1/2009 11:58:25 AM: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
5/1/2009 11:58:25 AM: Executing: ONCOMMANDINVALID
5/1/2009 11:58:25 AM: Que Exec: True, menu.skin, "Reset_Stars||SENDMSG;MediaDB_plugin;RCheck", False
5/1/2009 11:58:26 AM: Executing: Reset_Stars
5/1/2009 11:58:26 AM: Command not executed: Reset_Stars
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
5/1/2009 11:58:26 AM: Executing: ONCOMMANDINVALID
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SENDMSG;MediaDB_plugin;RCheck", False
5/1/2009 11:58:26 AM: Executing: SENDMSG;MediaDB_plugin;RCheck
5/1/2009 11:58:26 AM: Leave Exec: False, menu.skin, SENDMSG;MediaDB_plugin;RCheck, False
5/1/2009 11:58:26 AM: Enter Exec: False, menu.skin, , False
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "ONSKINSTART", False
5/1/2009 11:58:26 AM: Executing: SETVAR;AppToRun;MyApp01<<MyApp02<<MyApp03<<MyApp04 <<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyA pp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15< <MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyAp p21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<< MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp 32<<MyApp33<<MyApp34<<MyApp35<<MyApp36<<MyApp37<<M yApp38<<MyApp39<<MyApp40<<MyApp41<<MyApp42<<MyApp4 3<<MyApp44<<MyApp45<<MyApp46<<MyApp47<<MyApp48<<My App49<<MyApp50<<MyApp51<<MyApp52<<MyApp53<<MyApp54 <<MyApp55<<MyApp56<<MyApp57<<MyApp58<<MyApp59<<MyA pp60<<MyApp61<<MyApp62<<MyApp63<<MyApp64<<MyApp65< <MyApp66<<MyApp67<<MyApp68<<MyApp69<<MyApp70<<MyAp p71<<MyApp72<<MyApp73<<MyApp74<<MyApp75<<MyApp76<< MyApp77<<MyApp78<<MyApp79<<MyApp80<<MyApp81
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels01||SetAppLabels||SetIcons||Gamma Slider||ExtraPrograms||IndPoller_Add;MOBILEPHONE_I NCOMMINGCALL;2;ONPHONE_POPUP", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp01LB;Music
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels02", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp02LB;Radio
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels03", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp03LB;Video
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels04", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp04LB;DVD
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels05", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp05LB;XM
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels06", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp06LB;Sirius
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels07", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp07LB;Phone
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels08", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp08LB;Utilities
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels09", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp09LB;CD Ripper
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels10", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp10LB;TV
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels11", False
5/1/2009 11:58:26 AM: Executing: SETVAR;MyApp11LB;Weather
5/1/2009 11:58:26 AM: Que Exec: True, menu.skin, "SetCommandLabels12", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp12LB;Pictures
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels13", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp13LB;Games
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels14", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp14LB;Gauges
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels15", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp15LB;Browser
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels16", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp16LB;Settings
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels17", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp17LB;Destinator
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels18", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp18LB;Map Point
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels19", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp19LB;Streets & Trips
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels20", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp20LB;iGuidance
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels21", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp21LB;Gas Prices
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels22", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp22LB;Camera
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels23", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp23LB;Traffic Cams
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels24", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp24LB;Calendar
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels25", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp25LB;Media Copy
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels26", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp26LB;Skin Colors
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels27", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp27LB;Lotto
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels28", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp28LB;Net Radio
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels29", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp29LB;Radar
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels30", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp30LB;Scanner
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels31", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp31LB;HD Radio
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels32", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp32LB;External Apps
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels33", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp33LB;Skins
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels34", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp34LB;Sys Diag
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels35", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp35LB;GoogleEarth
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels36", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp36LB;Lyrics
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels37", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp37LB;Jukebox
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels38", False
5/1/2009 11:58:27 AM: Executing: SETVAR;MyApp38LB;TaskMan
5/1/2009 11:58:27 AM: Que Exec: True, menu.skin, "SetCommandLabels39", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp39LB;Gmaps
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels40", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp40LB;Theme
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels41", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp41LB;Wireless
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels42", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp42LB;Movie Showtimes
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels43", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp43LB;RRMedia
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels44", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp44LB;CNN News
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels45", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp45LB;Daytime Map
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels46", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp46LB;Destinator 7
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels47", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp47LB;Clean Screen
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels48", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp48LB;Tire Pressure
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels49", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp49LB;Phoco
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels50", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp50LB;CD Changer
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels51", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp51LB;Engine Monitor
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels52", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp52LB;phone tester screen
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels53", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp53LB;Garmin GPS
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels54", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp54LB;Brightness
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels55", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp55LB;Silabs Radio
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels56", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp56LB;Youtube
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels57", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp57LB;Mixer
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels58", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp58LB;DUN
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels59", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp59LB;<Unused>
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels60", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp60LB;<Unused>
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels61", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp61LB;<Unused>
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels62", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp62LB;<Unused>
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels63", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp63LB;<Unused>
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels64", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp64LB;<Unused>
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels65", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp65LB;<Unused>
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels66", False
5/1/2009 11:58:28 AM: Executing: SETVAR;MyApp66LB;<Unused>
5/1/2009 11:58:28 AM: Que Exec: True, menu.skin, "SetCommandLabels67", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp67LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels68", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp68LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels69", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp69LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels70", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp70LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels71", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp71LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels72", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp72LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels73", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp73LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels74", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp74LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels75", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp75LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels76", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp76LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels77", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp77LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels78", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp78LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels79", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp79LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels80", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp80LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels81", False
5/1/2009 11:58:29 AM: Executing: SETVAR;MyApp81LB;<Unused>
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetCommandLabels82", False
5/1/2009 11:58:29 AM: Executing: SetCommandLabels82
5/1/2009 11:58:29 AM: Command not executed: SetCommandLabels82
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
5/1/2009 11:58:29 AM: Executing: ONCOMMANDINVALID
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetAppLabels||SetIcons||GammaSlider||ExtraProgram s||IndPoller_Add;MOBILEPHONE_INCOMMINGCALL;2;ONPHO NE_POPUP", False
5/1/2009 11:58:29 AM: Executing: SETVAR;ButtonLabel;=MUSIC<<=RADIO<<=VIDEO<<=DVD<<=XM<<=SIRIUS<<=PHONE<<=UTILITIES<<=RIP CD<<=TV<<=WEATHER<<=PICTURES<<=GAMES<<=GAUGES STATS<<=BROWSER<<=SETTINGS<<=GPS<<=GPS<<=GPS<<=GPS <<=GAS PRICES<<=CAMERA<<=TRAFFIC CAMS<<=CALENDAR<<=MEDIA COPY<<=COLORS<<=LOTTO<<=NET RADIO<<=RADAR<<=SCANNER<<=HD RADIO<<=LAUNCH<<=SKINS<<=SYS DIAG<<=G. EARTH<<=LYRICS<<=JUKEBOX<<=TASK MAN<<=G MAPS<<=THEME<<=WIRELESS<<=THEATERS<<=RESCAN<<=CNN NEWS<<=DAYTIME<<=GPS<<=CLEAN SCREEN<<=TIRE MON<<=PHONE<<=LOAD CD<<=ENGINE<<=PHONE<<=GPS<<=Brightness<<=Silabs<<= Youtube<<=Mixer<<=DUN<<=UnUsed<<=UnUsed<<=UnUsed<< =UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUs ed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<= UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUse d<<=UnUsed<<=UnUsed<<=UnUsed
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "SetIcons||GammaSlider||ExtraPrograms||IndPoller_A dd;MOBILEPHONE_INCOMMINGCALL;2;ONPHONE_POPUP", False
5/1/2009 11:58:29 AM: Executing: SetIcons
5/1/2009 11:58:29 AM: Command not executed: SetIcons
5/1/2009 11:58:29 AM: Que Exec: True, menu.skin, "GammaSlider||ExtraPrograms||IndPoller_Add;MOBILEP HONE_INCOMMINGCALL;2;ONPHONE_POPUP", False
5/1/2009 11:58:29 AM: Executing: RUNQ;C:\Program Files\Road Runner\Skins\DigitalFX 4.0\Scripts\GammaSlider\GammaSlider.exe
5/1/2009 11:58:29 AM: Shell: "C:\Program Files\Road Runner\Skins\DigitalFX 4.0\Scripts\GammaSlider\GammaSlider.exe"
5/1/2009 11:58:30 AM: Que Exec: True, menu.skin, "ExtraPrograms||IndPoller_Add;MOBILEPHONE_INCOMMIN GCALL;2;ONPHONE_POPUP", False
5/1/2009 11:58:30 AM: Executing: SETVAR;Logofilename;Abarth.png
5/1/2009 11:58:30 AM: Que Exec: True, menu.skin, "SETVAR;FontName;Arial.png", False
5/1/2009 11:58:30 AM: Executing: SETVAR;FontName;Arial.png
5/1/2009 11:58:30 AM: Que Exec: True, menu.skin, "UserSwitch||CDLaunch||Counter||3DLogo||SetTempBac kground||PresetLoader||IGSettingLoader||SETVAR;RRL oaded;Loaded||ReLock", False
5/1/2009 11:58:30 AM: Executing: UserSwitch
5/1/2009 11:58:30 AM: Command not executed: UserSwitch
5/1/2009 11:58:30 AM: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
5/1/2009 11:58:30 AM: Executing: ONCOMMANDINVALID
5/1/2009 11:58:30 AM: Que Exec: True, menu.skin, "CDLaunch||Counter||3DLogo||SetTempBackground||Pre setLoader||IGSettingLoader||SETVAR;RRLoaded;Loaded ||ReLock", False
5/1/2009 11:58:30 AM: Executing: RUNQ;C:\Program Files\Road Runner\Skins\DigitalFX 4.0\Scripts\AutoLaunch.exe
5/1/2009 11:58:30 AM: Shell: "C:\Program Files\Road Runner\Skins\DigitalFX 4.0\Scripts\AutoLaunch.exe"
5/1/2009 11:58:31 AM: Que Exec: True, menu.skin, "Counter||3DLogo||SetTempBackground||PresetLoader| |IGSettingLoader||SETVAR;RRLoaded;Loaded||ReLock", False
5/1/2009 11:58:31 AM: Executing: RUNQ;C:\Program Files\Road Runner\Skins\DigitalFX 4.0\Weather\Counter.exe
5/1/2009 11:58:31 AM: Shell: "C:\Program Files\Road Runner\Skins\DigitalFX 4.0\Weather\Counter.exe"
5/1/2009 11:58:31 AM: Que Exec: True, menu.skin, "3DLogo||SetTempBackground||PresetLoader||IGSettin gLoader||SETVAR;RRLoaded;Loaded||ReLock", False
5/1/2009 11:58:32 AM: Executing: 3DLogo
5/1/2009 11:58:32 AM: Command not executed: 3DLogo
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
5/1/2009 11:58:32 AM: Executing: ONCOMMANDINVALID
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SetTempBackground||PresetLoader||IGSettingLoader| |SETVAR;RRLoaded;Loaded||ReLock", False
5/1/2009 11:58:32 AM: Executing: BYVAR;BKGNDSET;BackgroundNotSet<<BackgroundIsSet
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "BackgroundIsSet", False
5/1/2009 11:58:32 AM: Executing: BackgroundIsSet
5/1/2009 11:58:32 AM: Command not executed: BackgroundIsSet
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "PresetLoader||IGSettingLoader||SETVAR;RRLoaded;Lo aded||ReLock", False
5/1/2009 11:58:32 AM: Executing: BYVAR;EQPreset;SetRock<<SetPop<<SetRap<<SetClassic al<<SetJazz<<SetPhone
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SetRock", False
5/1/2009 11:58:32 AM: Executing: SETIND;!Rock;ON
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classic al;OFF||SETIND;!Jazz;OFF||SETIND;!Phone;OFF", False
5/1/2009 11:58:32 AM: Executing: SETIND;!Pop;OFF
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!J azz;OFF||SETIND;!Phone;OFF", False
5/1/2009 11:58:32 AM: Executing: SETIND;!Rap;OFF
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;! Phone;OFF", False
5/1/2009 11:58:32 AM: Executing: SETIND;!Classical;OFF
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SETIND;!Jazz;OFF||SETIND;!Phone;OFF", False
5/1/2009 11:58:32 AM: Executing: SETIND;!Jazz;OFF
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SETIND;!Phone;OFF", False
5/1/2009 11:58:32 AM: Executing: SETIND;!Phone;OFF
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "IGSettingLoader||SETVAR;RRLoaded;Loaded||ReLo ck", False
5/1/2009 11:58:32 AM: Executing: BYVAR;pauseonvoice;LoadAUTOPauseOFF<<LoadAUTOPause ON
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "LoadAUTOPauseON", False
5/1/2009 11:58:32 AM: Executing: SETIND;!AutoPauseOn;ON
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SETIND;!AutoPauseOff;OFF", False
5/1/2009 11:58:32 AM: Executing: SETIND;!AutoPauseOff;OFF
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "BYVAR;igautosw;LoadAUTOGPSOFF<<LoadAUTOGPSON" , False
5/1/2009 11:58:32 AM: Executing: BYVAR;igautosw;LoadAUTOGPSOFF<<LoadAUTOGPSON
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "LoadAUTOGPSOFF", False
5/1/2009 11:58:32 AM: Executing: SETIND;!AutoGPSOn;OFF
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SETIND;!AutoGPSOff;ON", False
5/1/2009 11:58:32 AM: Executing: SETIND;!AutoGPSOff;ON
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "SETVAR;RRLoaded;Loaded||ReLock", False
5/1/2009 11:58:32 AM: Executing: SETVAR;RRLoaded;Loaded
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "ReLock", False
5/1/2009 11:58:32 AM: Executing: ReLock
5/1/2009 11:58:32 AM: Command not executed: ReLock
5/1/2009 11:58:32 AM: Que Exec: True, menu.skin, "IndPoller_Add;MOBILEPHONE_INCOMMINGCALL;2;ONPHONE _POPUP", False
5/1/2009 11:58:33 AM: Leave Exec: False, menu.skin, IndPoller_Add;MOBILEPHONE_INCOMMINGCALL;2;ONPHONE_ POPUP, False
5/1/2009 11:58:33 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||EXITMENU", False
5/1/2009 11:58:33 AM: Que Exec: True, menu.skin, "ONBTNPRESS||EXITMENU", False
5/1/2009 11:58:33 AM: Que Exec: True, menu.skin, "EXITMENU", False
5/1/2009 11:58:33 AM: Executing: EXITMENU
5/1/2009 11:58:35 AM: Que Exec: True, exit_menu.skin, "ONSCREENCHANGE", False
5/1/2009 11:58:35 AM: Leave Exec: False, exit_menu.skin, ONSCREENCHANGE, False
5/1/2009 11:58:36 AM: Enter Exec: False, exit_menu.skin, "ONBTNPRESS||KillWinamp||QUIT", False
5/1/2009 11:58:36 AM: Que Exec: True, exit_menu.skin, "ONBTNPRESS||KillWinamp||QUIT", False
5/1/2009 11:58:37 AM: Que Exec: True, exit_menu.skin, "KillWinamp||QUIT", False
5/1/2009 11:58:37 AM: Executing: RunQ;C:\Program Files\Road Runner\Skins\DigitalFX 4.0\scripts\Kill_Task.exe|winamp.exe
5/1/2009 11:58:37 AM: Shell: "C:\Program Files\Road Runner\Skins\DigitalFX 4.0\scripts\Kill_Task.exe" winamp.exe
5/1/2009 11:58:37 AM: Que Exec: True, exit_menu.skin, "QUIT", False
5/1/2009 11:58:37 AM: Executing: SendMsg;RRCDRip;showplugin
5/1/2009 11:58:37 AM: Que Exec: True, exit_menu.skin, "bye", False
5/1/2009 11:58:37 AM: Executing: QUIT
5/1/2009 11:58:37 AM: Enter Exec: True, exit_menu.skin, "ONEXIT", False
5/1/2009 11:58:37 AM: Queued: "ONEXIT"
5/1/2009 11:58:37 AM: Shutdown: (1)
5/1/2009 11:58:37 AM: Shutdown: (2)
5/1/2009 11:58:37 AM: Shutdown: (3)
5/1/2009 11:58:37 AM: Shutdown: (4)
5/1/2009 11:58:37 AM: Plugin Manager: ALL Plugins unloaded.
5/1/2009 11:58:37 AM: Shutdown: (5)
5/1/2009 11:58:37 AM: Shutdown: (6)
5/1/2009 11:58:37 AM: Shutdown: (7)
5/1/2009 11:58:38 AM: Shutdown
My Work Thread:
http://www.mp3car.com/vbulletin/show-off-your-project/72552-mp3-project-for-land-cruiser-done.html
Source switcher for Lill
http://www.mp3car.com/vbulletin/show...d=1#post841007
My Work Thread:
http://www.mp3car.com/vbulletin/showthread.php?t=72552
I found a program called CheckRRLoad.exe in the scripts folder of the skin. When I run it I get another AutoIt Error dialog with "Error Variable must be of type 'Object'". Is there any further debug output from that thing?
My Work Thread:
update: I am SURE this has something to do with the plugin manager because when I use the plugin manager in the skin I get the same error when I exit. So I am closer but I still have no idea how to solve it.
My Work Thread:
well, to check, rename the CheckRRLoad.exe and then use the plugin manager and see if you still get that error. if so, then its the pluginmanager that is causing it.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
I recieve the same error when trying to run the wifi plugin, but on my WinXP Lite version. My setup on the computer works fine.
Is there any requirements for AutoITv3 that may not be installed or possibly the plugins themselves?
AutoIt is self contained and requires no extras besides whatever is required by the plugin. The plugin might be trying to talk to something that is missing on your "Lite XP". Like did you strip out the any of the wireless stuff from your install?
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
I assumed this was the issue and that AutoIT is self contained. The wireless issue could be as you stated. I used the Basic Version of TinyXPv09. I will update the install with the driverpack included to bump it up to the minimal settings instead. Thanks for the response.
Thats the same XP version that I also use in the car and don't recall having any problems with the wifi plugin.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
I believe the install was the Basic (32mb) Barebones with No IE/OE/WMP. Option 8?
Well the error is an AutoIT error in the popup name and the error is related to line 1 or something simmila
' "Error due to the variable expected should be an "object". '
