Results 1 to 10 of 12
Thread: skin error
    Mar 2009
    skin error
    Hi guys,
    I'm in the process of trying to move over from CF to RideRunner
    Now RR has installed fine - so the frst thing I did was to change the skin, so I changed to the 'simplistique' skin,,,,all good!
    I keep looking for other skins and came across digital FX 4.0 and igoBMW transparent........I installed these into the proper folders and I'm able to select them from within RRconfig.....the also show up in the preview check with RRconfig, but when I load up RR all I get is the load screen of the skin for a second then this error:
    "does not contain a valid skin! check your settings and try again. Details in debug.txt"
    I've re-installed RR a couple of times but no joy. any pointers guys
    cheers
    Lewis
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    are you sure the skin folder you're pointing to has the skin files installed? Meaning its not just an empty or parent folder. I've seen this happen before
    Live mp3Car Facebook Chat
    Mar 2009
    yeah I think so....there ar e86 files in both the zip for this skin and in the skins folder on my c: drive
    prt screen of the igoBMW folder on my hard drive:
    Mar 2009
    Name:  untitled (Medium).bmp
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    go back to RRconfig and confirm your settings, then make sure you save them before exiting.
    If this doesnt work I would say you have a pretty unique problem
    New Age Garmin - Skin for RR
    Mar 2009
    re-checked things....all 'seems' fine - and if I switch to carwings skin ....it works. I'm obviously doing something wrong....may try a diff computer
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Normally the only reasons for an invalid skin error are general.ini or menu.skin not being there or being corrupt.
    So check those files, open them in notepad to check them.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It could be some sort of error/issue with the menu.skin file.. try using the skin switch function within RR to see if it loads.. in any case I'll try to download the igobmw skin and try it myself to see..
    Ride Runner RR's Myspace
    Newbie leeman01's Avatar
    Aug 2008
    Pikeville, North Carolina, United States
    Looking at the screen shot, it also looks like an older installer may have been used? I thought RR now installed default to c:/Program Files/Ride Runner/ now, not "Road Runner".
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Maybe this is just an old RR installed, cause I just downloaded the IgoBMW skin, placed in my skins folder and it worked right away, both switching inside RR and starting up RR directly into it.
  1. RRMobile Resurrection
    By VorTechs in forum RR Plugins
    Last Post: 04-04-2008, 10:22 PM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  4. error when returning to video and skin
    By CdRsKuLL in forum RR Bug Tracker
    Last Post: 03-14-2005, 01:32 PM
