sorry my fault rrdebug.txt please sorry thats what i meant to ask for
in rr folder, but you may need to switch it on in rrconfig or add these to rr.ini should be at the top of rr.ini
debugmode=true
debugfresh=true
if debug is not on switch on , then run RR and select a game then post debug.txt
rrextended is NOT installed , thats your problem
iam loading instal.bat (@RegSvr32 RRExtended.dll)
and rebout system!
RUSSIA - WINER!!!
where do you have rrextended folder
should be in RR root\plugins
unreg dll and move to plugins folder,
First copy the following text into notepad and save as reghelp.reg file.
Right-click the .reg file and select merge to add these keys to the registry.
You should then have Register and Unregister on your context menu whenever you right-click a dll file.
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\dllfile\Shell]
[HKEY_CLASSES_ROOT\dllfile\Shell\Register]
[HKEY_CLASSES_ROOT\dllfile\Shell\Register\command]
@="regsvr32.exe \\\"%1\\\""
[HKEY_CLASSES_ROOT\dllfile\Shell\UnRegister]
[HKEY_CLASSES_ROOT\dllfile\Shell\UnRegister\command]
@="regsvr32.exe /u \\\"%1\\\""
