Results 1 to 5 of 5
Thread: Problem with editing button via 3.0/4.0 Button Editor (or simply editing Exectbl.ini
    Jun 2009
    Hi all,
    I'm a new carpc user, just installed the latest rr + DFX 4.0 skin and have been doing some config b4 set it up in the car. However I run into a very odd problem and I'm totally stucked, hoping someone would be able to help:
    1. Was trying to setup the garmin mobilePC path to "D:\GarminMobilePC\Que.exe" (the default is...for some reason pointing to "I:\GarminMobilePC\Que.exe") using the "3.0/4.0 Button Editor By BlueZX3", saved it and restarted rr, then none of the button (except only the Music button)works again, thay all give no response when click.
    Spent almost an hour and figured it out it doesn't matter if I use the button editor or not, as soon as I have changed and saved anything in the Exectbl.ini (even adding a "-" into an existing line), those buttons won't ever work. Tried to reverse the change --- no luck, it only works after I copy across the original copy.
    I have attached the live debug log if they would help:
    1st run.txt ----> log when I start rr (before editing Exectbl.ini)
    on gps button click.txt ---> log when I click the gps button (before editing Exectbl.ini)
    after edited.txt ---> log when I click all the buttons in menu (after edited Exectbl.ini)
    Exectbl.ini.txt ----> after edit and reversed (only thing I changed was the path from "I:\" to "D:\" in "MyApp53")
    Exectbl_BACKUP.ini.txt ----> original copy
    Attached Files Attached Files
    Jun 2009
    Please no one able to help ?
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    what OS?
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ok, so I see what your problem is...
    Open your exectbl file and search for 'SkinButton1'. You should have 1 thru 16 each on seperate lines but if you look, they all got put on the same line. Somehow the button editor didn't use both the end-of-line characters, which is a "CarriageReturn" & "LineFeed". I see the linefeed one but the carriagereturn ended up being a "?" instead...
    Code:
    "SkinButton1","BYVAR;MAINBUTTON1;$AppToRun$?"SkinButton2","BYVAR;MAINBUTTON2;$AppToRun$?"SkinButton3","BYVAR;MAINBUTTON3;$AppToRun$?"SkinButton4","BYVAR;MAINBUTTON4;$AppToRun$?"SkinButton5","BYVAR;MAINBUTTON5;$AppToRun$?"SkinButton6","BYVAR;MAINBUTTON6;$AppToRun$?"SkinButton7","BYVAR;MAINBUTTON7;$AppToRun$?"SkinButton8","BYVAR;MAINBUTTON8;$AppToRun$?"SkinButton9","BYVAR;MAINBUTTON9;$AppToRun$?"SkinButton10","BYVAR;MAINBUTTON10;$AppToRun$?"SkinButton11","BYVAR;MAINBUTTON11;$AppToRun$?"SkinButton12","BYVAR;MAINBUTTON12;$AppToRun$?"SkinButton13","BYVAR;MAINBUTTON13;$AppToRun$?"SkinButton14","BYVAR;MAINBUTTON14;$AppToRun$?"SkinButton15","BYVAR;MAINBUTTON15;$AppToRun$?"SkinButton16","BYVAR;MAINBUTTON16;$AppToRun$?
    Is the first time I've seen this kinda error with that tool. What OS and what language?
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2009
    xp pro sp3, english but the unicode set to traditional chinese (taiwan)
    I wasn't sure if that was related to the button editor, because it happened the same way even if i open it up from text editor.
  1. iGuidance Hacks
    By pbarrette in forum GPS
    Last Post: 12-28-2007, 04:06 PM
  2. BMW iBus problem - Not detecting Button Pressed
    By captain_jim1 in forum Software & Software Development
    Last Post: 06-14-2006, 04:10 PM
  3. problem with ExecTBL.ini priority
    By liquid_smoke in forum Road Runner
    Last Post: 10-01-2005, 08:11 PM
  4. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
