Results 1 to 10 of 12
Thread: Skin Problem
    Aug 2007
    Roma
    Skin Problem
    Hi Guys,
    I proceed with my skin for Road Runner, I have modified the graphics :-)
    Before, Version 1:
    Now, Version 2:
    Please I have a problem with a insert slider_play, I remember that I use as Carwing skin base, and I want to add the slider bar, for example the slider bar of Iphone_Beta skin...
    please see the image :
    I insert the code as in figure, but when I load the Skin and I load the audio file, the slider_play is trasparent, but work if I use the mouse !!!!!!
    HELP ME !!!
    after I don't understand the field : 0 , Style , H2 ... ????
    thanks.
    Riko
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is in skin commands.txt:
    Code:
    /, (S) Slider
    /,                                    Slider
    /,  x   y   w   h   x1  y1  w1  h1  O Style Pointer file path h2  Code  tooltip
    SXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,H,01,"SLIDER3\POINTER.gif",XXX,CODE,""
    The above tag creates a slider view within the given boundaries (x,y,w,h).
    x1,y1,w1,h1 define the area in which to display the Slider Styles (Images) -- This area is also the area
    where clicking with the mouse will change the slider value.
    O is the oriantation (H=Horizontal, V=Vertical).
    The Slider Style is the number of the style (Y Tag below) with the path to the images to use.
    *Note: You can alternatively specify a file name like "BAR.PNG" as the slider style for a single image slider.
    Pointer is the path to the image to use as the pointer/tick in the slider.
    h2 is the is the thickness or height of the pointer image.
    CODE is a valid SLIDER CODE defined below.
    /, (Y) Slider Style
    /,  Back Slider file path
    YXX,"SLIDER3\SLIDER_*.gif"
    The above defines a style (set of images) to use with a slider. Has no effect alone.
    The images should range from 0 to 20 -- the * marks where to insert the number of image to load.
    XX is the style number to be used in the SLIDER definition.
    If you have more problems after reading that, just let us know..
    Ride Runner RR's Myspace
    Aug 2007
    Roma
    thanks GUINO,
    but I dont see the slider bar, follow I write my code :
    RoadRunner Skin
    RRScreen audio_player
    audio_player_off.png,audio_player_off.png,audio_pl ayer_on.png,audio_player_down.png
    L,757,178,40,20,255,255,255,12,"Larabiefont","Trac ktime","Right"
    L,757,144,40,20,255,0,0,12,"Larabiefont","CURRENTT RACKTIME","Right"
    L,698,17,101,30,0,255,0,20,"Larabiefont","Time","C enter"
    L,184,562,29,30,0,255,0,12,"Larabiefont","VOLUME", "Center"
    Y01,"slider_play\pointer.gif"
    S02,450,485,204,39,451,486,200,25,H,01,"slider_pla y\pointer.gif",11,"SONGPOS",""
    INC,Bottomtext.txt
    L,757,93,40,20,0,255,0,12,"Larabiefont","Status"," Right"
    B,704,388,97,145,"PLAYSOUND;C:\Documents and Settings\Federico\Documenti\file.wav||load;audio_b rowser.skin",
    B,-1,225,51,74,"PGUP",
    B,-1,302,51,74,"PGDOWN",
    B,-1,388,97,145,"DOWN",
    B,-1,64,97,145,"UP",
    B,737,546,64,55,"EXIT",
    B,512,546,69,55,"PLAYSOUND;C:\Documents and Settings\Federico\Documenti\mixer.wav||MIXER",@SKI N@
    B,655,546,78,55,"SHUFFLE/REPEAT",
    B,220,546,69,55,"MUTE",
    B,360,489,83,112,"PLAY",
    B,455,546,54,55,"NEXT",
    B,292,546,54,55,"PREV",
    B,-1,546,64,55,"VOL-",
    B,66,546,78,55,"VOL+",
    L,587,577,20,20,255,0,0,10,"Larabiefont","BYIND;sh uffle;<<=S","Center"
    L,587,552,20,20,255,0,0,10,"Larabiefont","BYIND;re peat;<<=R","Center"
    IL,PL,transparent.bmp,sel.bmp,,0,50,60
    S,140,93,407,389,255,255,255,255,0,0,255,0,0,255,0 ,0,255,0,0,false,18,"Larabiefont:B"
    J,559,220,123,158
    /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
    IL,PL,transparent.bmp,sel.bmp,end.bmp,2,50,80
    END
    HELP !!!!!!!!!
    Aug 2007
    Roma
    THANKS GUINOOOOOOOOOOOOOOOOOOOO...
    I resolve my problem :-) ....
    please I have another problem, in the image section I don,t see the preview image , i post my code :
    RoadRunner Skin
    RRScreen Picviewer
    picture_viewer_off.png,picture_viewer_off.png,pict ure_viewer_on.png,picture_viewer_down.png
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    /, I, x, y, w, h, Code;INDICATORCODES
    B,-1,225,53,70,"BROWSE",
    B,-1,307,53,70,"BACK",
    B,-1,387,103,148,"DOWN",
    B,-1,66,103,148,"UP",
    I02,144,97,350,350,"PICTURE"
    L55,144,97,350,350,,,,,,"EXEC;LOAD;picture.skin||" ,""
    /, S, x, y, w, h, fore R;RGB, G, B, back R;RGB, G, B, folder R;RGB, G, B, file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, Font name
    S01,500,88,182,421,255,255,255,255,255,255,255,255 ,255,255,255,255,255,255,255,255,128,0,TRUE,14,"La rabiefont"
    SD,00,03,30,30,"$picspath$","*.jpg;*.bmp;*.gif;*.p ng",FALSE
    IL01,DL,transparent.bmp,sel.bmp,1,70,50,
    END
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't see anything wrong with the skin code.. as long as you select a valid image file in the list, it should display in the preview space.
    I would only suggest moving the IL line up (before the S01 line).
    Aug 2007
    Roma
    Hi,
    I have try to moving the IL before the S01 line, but I don't see the preview.
    If I use the carwing skin I see the preview, the difference with my skin is the graphics...
    mmmmmmmmmmmmmm :-(
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you are not seeing the preview IMAGE or the FILES list so you can select and see the preview ?? Also, do you have the images INSIDE the MP3 files by any chance ? (Cause if you do, you would need the mp3art plugin in your skin as well)
    Aug 2007
    Roma
    Hi Guino,
    I resolve, I delete the Picture_on.png, because with the touchscreen the onmouseover I don't use... I rename the file into Picture.skin and I see the preview :-) ...
    Aug 2007
    Roma
    Hi Guino,
    Hi at all,
    please friends help me, I have many little problems (please see my video [media]http://www.youtube.com/watch?v=aO41ni-PDtk[/media] ),
    When I load the Radio_Player.skin and after I load or Audio or Video .skin, the volume set to 0%... This problem is present with all skin (Carwing, BMW-E36) ... GRRRRRRRRR..
    Aug 2007
    Roma
    I resolve the audio problem to set in RRconfig in the radio section the output line ( Sintetize SW) ... but I don't understand as when I load the radio, after the audio or video player and after return in radio, I don't listen !!!, I must exit to RR :-(
    Why ?:-(
  1. How To: Get your new skin out to the masses.
    By monkeyracer in forum RR FAQ
    Last Post: 07-19-2008, 08:59 AM
  2. "Avic'ted" - Pioneer Styled Skin
    By monkeyracer in forum RR Skins
    Last Post: 10-19-2007, 11:08 AM
  3. StreetDeck Skin Problem
    By Solixa in forum StreetDeck
    Last Post: 06-27-2007, 11:27 AM
  4. RR w/Blue Devil Skin - XM Problem
    By Bump in forum Road Runner
    Last Post: 12-20-2006, 10:10 AM
  5. problem with Pioneer skin visulisations
    By chewEboy in forum RR Skins
    Last Post: 01-26-2006, 07:03 AM
