Again, U people need to give more info in order to get info...
Did you :
use the installer?
Run the config and set all your paths?
Check your ..\skins\ folder to make sure that the folder is there ("Carwings_Dynamic")?
Check that you have both a General.ini and Menu.skin in that folder?
Which RR version are you trying to use?
Just some things to try look for first.
PS. In future, if posting about a bug/issue also list important info that help others to help you. Most will just pass on by if they see that the poster has NOT listed any or enough info to help solve the problem.
LinkBack URL
About LinkBacks
The skin folder is within another folder - been there done that!
