Results 1 to 9 of 9
Thread: Feature Request: dynamically loaded skin components
    Jun 2008
    Atlanta, GA
    At the simplest level I'm asking for support for conditionals in skin files. I.e.:
    if x = y
    <some component -- button, IMG, application, custom list>
    else
    <some other component -- button, IMG, application, custom list>
    endif
    When the skin is loaded RR would load one or the other based on the values of x and y. I know you can already hide labels by changing the labelcode to nothing, but this would allow skinners to make one skin that can be used for multiple things based on some variables at load time. Like, say:
    1. Load music player with album art displayed
    2. Hit button for visualisation
    3. Skin sets a variable, tells RR to reload this screen
    4. Load music player with visualization where album art was
    And you wouldn't need multiple .skin files to pull it off.
    At a more complex level it would be great to be able to dynamically load skin elements WITHOUT reloading the skin. Same example as above, except RR loads BOTH elements, but only displays/draws the one based on the value of x. In this example we may need to limit it to only a true/false instead of multiple values for x.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This would be another push RR over top feature...
    I would think something along the lines of these type cmds...
    DELBUTTONID;BXX
    ADDBUTTON;<whole button define line here>
    DELLABELID;LXX
    ADDLABEL;<whole label define line here>
    Ect...
    Dont see something like this being really that hard to both use and implement....
    RR Coding Team Comments????
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Mitch and I were talking about showing/hiding buttons on the skin.. similar to the flash objects.. right now, objects are created only from the .skin file and can't be unloaded (although labels/flash/indicators can be hidden and even buttons can be modified). Making RR load more objects in run-time is not that hard. Making it UNLOAD objects in run-time may be a bit of a trouble -- this may require some re-structuring of the "table" that stores the objects loaded on screen, but with some effort it could be done.
    Ride Runner RR's Myspace
    Jun 2008
    Atlanta, GA
    I think that at least the simplistic part of my original post should be really simple. Basically when parsing the .skin file, only load into the table the objects in either the IF or ELSE case of the statement. Since you're reloading the whole screen there's no worry about unloading objects from the table. This would be a welcome change in the near term.
    For Blue's idea, I think we could just use:
    ADDITEM;<definition>
    DELITEM;Xxx
    And the object code itself should be enough to tell RR which object it is (L01, B01, etc.). Only problem there is a lot of people are gonna have to tweak their skins to not just have 50 L01s (like me... )
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That makes sence, espec if you del a button in the middle of the buttons array, that could be a bit messy if u latter use the setbuttonxx command b/c that btn would no longer be in that button array element but up one.
    Better to hide/show would be probably best and easies for both US an skinners...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    What you are describing can be done with skin code IF you are using a reloadscreen command by way of INC in the main skin file.
    i.e.
    Audio_player.skin
    Code:
    RoadRunner Skin
    RRScreen menu
    INC,inc_audio_player$displayvariable$.skin
    End
    inc_audio_player0.skin
    Code:
    <Has code to display album art>
    inc_audio_player1.skin
    Code:
    "VISU","SETVAR;displayvariable;1||RELOADSCREEN||VI SU"
    The way the skin would work is that on initial loading, audio_player.skin will load it with the album art code (displayvariable = 0).
    As soon as you hit "VISU" button, it will change $displayvariable$ to 1 and reloadscreen will load the code that display an application area instead of album art.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Jun 2008
    Atlanta, GA
    Quote Originally Posted by Sal R. View Post
    i.e.
    Audio_player.skin
    Code:
    RoadRunner Skin
    RRScreen menu
    End
    Code:
    Code:
    Clever! But I still think adding support for something like this natively would be good.
    Aug 2006
    Sun Diego
    Quote Originally Posted by spamminator View Post
    Don't get me wrong, if this could be implemented, you know i'd be using it.
    More a skinner's FYI if it becomes difficult to execute.
    Aug 2006
    Sun Diego
    DELBUTTONID;BXX
    DELLABELID;LXX
    Ect...
    The specific button ID is a real good. All my BXX, LXX, IXX codes are all 00's except for the ones I want specific control over.
    Me likey.
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. Replies: 65
    Last Post: 07-23-2008, 03:03 AM
  3. How To: Get your new skin out to the masses.
    By monkeyracer in forum RR FAQ
    Last Post: 07-19-2008, 08:59 AM
  4. Loaded MC2.0 skin, doesnt work
    By andres2882 in forum Road Runner
    Last Post: 09-27-2006, 04:42 PM
  5. Dependencies
    By Nobias in forum PhoneControl
    Last Post: 01-30-2005, 03:38 AM
