Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
Thread: Experimental skin : Phlikr
  1. #11
    Apr 2006
    Maryland
    Yes that can be easily changed. I just put no guesture areas around the screen except those areas.
    It's very controlled at the moment just because i'm still figuring out the best way to integrate this into skins. The code is actually very simple and i wonder why I haven't seen this done before.
  2. #12
  3. #13
    Nov 2004
    St Louis
    Just a thought to consider:
    Could this be setup so the first swipe pulls up the appropriate menu, then the next swipe toggles through the options, and after say 3 second of no input the skin changes to the selected screen? I think it would be so much cooler if the swipes only toggled thru the menus and after a designated time of no input, it would then switch to the highlighted item. You would probably need to add a "CANCEL" menu option in all menus, so if you change your mind it would remain on the current screen after the timeout.
  4. #14
    Apr 2006
    Maryland
    Hmm, that's an interesting idea GizmoQ. I was actually playing around with a similar idea, but reading your post has given me a refinement I want to explore further. Thanks!
  5. #15
    May 2006
    Calgary, Alberta
    Wow, that's dope. I'd try it out.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  6. #16
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Very cool idea.
    One thing that I've noticed they do on the iPhone app store is that you scroll down vertically to read about the app and when you get to the screenshots, you can sweep right to left to see one after the other.
    An idea for this skin would be to allow right/left or left/right sweeps take you to the main functions and if you wanted to see the options, you would sweep up/down.
    If you did this, I'd always have a 'home' menu button or area you could touch to get back quickly.
    Want to:
  7. #17
    Apr 2006
    Maryland
    Currently, I have predefined groups and predefined pages in a locked order. In the final release, I hope to make these user definable and enable the user to make custom groups. That's the goal at least...
  8. #18
    Apr 2006
    Maryland
    - An idea for this skin would be to allow right/left or left/right sweeps take you to the main functions and if you wanted to see the options, you would sweep up/down.
    I thought about this earlier as well, but sliders on certain screens kept interfering. The hard part is that instinctively people want to swipe in the middle of the screen and unfortunately sliders, ilists, playlists, etc. can interfere with that. I realize you can put NG areas around sliders, but when a playlist takes up most of the screen, I just can't put a NG area on that since it defeats the purpose of the swiping motion.
    Keep the comments coming! I think i've come up with at least 3 different approaches from all of your comments...
  9. #19
    Apr 2006
    Maryland
    I don't suppose there is an indicator for gestureson / guesturesoff is there? Just making sure before I define a custom one.
    So I will probably release an alpha of the version you see in the above posts, just so you guys can give opinions on the sweeping gesture. A lot of the skins and functions are not available, and are instead have a fake skin to hold it's place.
    I have already begun working on a newer version where I now just have one gesture area instead of two, and i made it bigger.
  10. #20
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Quote Originally Posted by Bugbyte View Post
    This function is SOOOOOOOOOOO nice! Love it! But I did not notice this before installing OS 3.0 on my iPhone.. They used to have "click for screens" type of function. Like Cydia still got it.
  1. RockCar Front End v0.0.154 - Skin Editor Updates
    By Hessian in forum Software & Software Development
    Last Post: 11-21-2008, 10:40 PM
  2. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 08:58 PM
  3. TEKNIK3 - Concept Skin
    By Valheru in forum RR Skins
    Last Post: 05-27-2008, 12:26 PM
  4. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 09:50 AM
