Results 1 to 8 of 8
Thread: question with elite skin
    Jan 2006
    Im using the elite skin for my new setup and when I booted up my carpc the skin does not fill the entire screen. im guessing its the resolution, i tried multiple resolutions and nothing is making it fit. what am I doing wrong??
    Thanks!
    Constant Bitrate almera's Avatar
    Aug 2004
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    When installing the skin, make sure to select the correct resolution. There is a option as to what version you would like to install. Select either 800*480 / 16:9 widescreen or 800*600 / 4:3 screen. The 800*600 will stretch the skin to fill your screen.
    Jan 2006
    Where can I select that? Because when I was installing the skin I do not remember it asking me what resolution I would like?
    Lets say im wrong, which I probably am, my memory is horrible, Can I change it after it has been installed?
    Thanks!
    Jan 2006
    Just read everything about how to change the resolution from 480 to 600
    Question though, if I wanted to use it at designed resoltion the 480, how would I go about making my screen that resolution. 600 is the biggest I have in the settings??
    Thanks!
    May 2006
    Calgary, Alberta
    I think it's general.ini, can't remember. The resolution is stored in there, had to change it here myself as well. For some reason my 16:9 Xenarc screen defaults to 800x600 and I can't change it. So I install the 16:9 version on my 16:9 screen and it looks like trash. I got to edit it back to 4:3 and it looks good. Stupid Xenarc.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jan 2006
    Quote Originally Posted by Maheriano View Post
    How do you edit it back to 4:3??
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by djurchicprelude View Post
    Check this post:
    http://www.mp3car.com/vbulletin/rr-r...ml#post1260473
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. Windows Media Player 11 skin Question
    By xtheenderx in forum RR Skins
    Last Post: 12-03-2008, 04:04 PM
  3. Replies: 65
    Last Post: 07-23-2008, 03:03 AM
  4. "Avic'ted" - Pioneer Styled Skin
    By monkeyracer in forum RR Skins
    Last Post: 10-19-2007, 11:08 AM
