Carwings Dynamic Lite - errors and enhancements ???
Hi!
Have Hauppauge WinTV-HVR-1110 PCI DVB-T, FM Radio card on Atom MB. My problem is, that i cannot set up the the Radio application.
First:
I have no Radio button under Carwings d. lite !!! Yes, XM and Sirius, but not standard radio!
Second:
If i try to set Radio->Radio(WinTV), then after save and start RR Config again i have nothing as Radio application in the box!!!
That other users have the same problem, look here (i think - not solved yet):
http://www.mp3car.com/vbulletin/road...erunner-8.html
How to solve this problem? How to get this card to work with RR???
Third:
The same problem - how to install TV on the RR ???
Why is the Carwings dynamic lite skin so poor supported? It may be the best suported skin on this forum, because it is the standard installed skin in RR! We can say - the reference skin. I can say - all software enhancements, all plugins must in first way support the Carwings d.lite skin and first after it the other skins! It is right, or not?
Thank you,
Feri
Problems still with phone plugin
Quote:
RideRunner screen loading error!
While loading: freefone.skin
freefone.skin not found
What is the best way to made working the phone plugin with standard RR installation?
If i do run the standard installation exe, then i got this message. True - no phone installed. If i try to install Mobilephone.Net_setup1.14, then i got the same message again!
PLEASE! What to do? I have found relative complicated way, but it is not a solution! A good - step by step - howto is needed. Or errorfree instalation routines - for RR and phone plugin. Lambosprit told me, that it is problem of RR and Carwings dynamic lite skin - not of phone plugin. So i like to know, if there is someone, that can give good guide to installation of phone plugin into standard instalation of Ride Runner! PLEASE! I and many others wish this info many times before and nobody can give answer?
Thx,
Feri
