Results 1 to 9 of 9
Thread: Carwings Dynamic Lite - errors and enhancements ???
    Aug 2009
    Hi!
    Have Hauppauge WinTV-HVR-1110 PCI DVB-T, FM Radio card on Atom MB. My problem is, that i cannot set up the the Radio application.
    First:
    I have no Radio button under Carwings d. lite !!! Yes, XM and Sirius, but not standard radio!
    Second:
    If i try to set Radio->Radio(WinTV), then after save and start RR Config again i have nothing as Radio application in the box!!!
    That other users have the same problem, look here (i think - not solved yet):
    http://www.mp3car.com/vbulletin/road...erunner-8.html
    How to solve this problem? How to get this card to work with RR???
    Third:
    The same problem - how to install TV on the RR ???
    Why is the Carwings dynamic lite skin so poor supported? It may be the best suported skin on this forum, because it is the standard installed skin in RR! We can say - the reference skin. I can say - all software enhancements, all plugins must in first way support the Carwings d.lite skin and first after it the other skins! It is right, or not?
    Thank you,
    Feri
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I agree
    May 2008
    Bordeaux, France
    Do you have installed the winamp tv plugin ? winamp tv plugin
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1-The HD Radio option in Carwings should work for any "standard" radio as well (i.e. WinTV)
    2-The WinTV option in the Config works, it just reloads to "None" when you re-open the config -- this needs to be fixed, but selecting WinTV in the config DOES work.
    3-The WinTV cards supported are the ones running THE RADIO32 APPLICATION -- I do not know if your card can work/comes with the Radio32 application.
    4-DVB-T tuning (both audio/tv) MAY BE POSSIBLE using the latest winamp tv plugin -- you'll need to search and play around with it to see if it will work or not.
    Ride Runner RR's Myspace
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I agree with the carwings situation above.
    I think for a plugin to be featured in the "released" forum, it should have at least the carwing skin ready (if applicable, some plugins are just extra commands, etc.). Just my .02c worth.
    Aug 2009
    Radio
    Aha, what i need to set for Radio?
    1.)
    HD Radio settings are a little bit complicated for me - because:
    com port - what for, i don't use it ?
    line plugin, or line input - Wave, or what for one - the sound comes via PCI ?
    2.)
    Radio not configured
    If i set it to WinTV, the RR tell me this. And yes, the Radio (not sure, if the needed) is here. If i start RRconfig, then i set WinTV and as "radiator path" this:
    "C:\Programme\WinTV\WinTV7\Radio\Radio.exe"
    The above message is the same. If i set the full path to the WinTV7.exe application, again the same!
    What need i set up, to made radio on the Hauppauge card to work?
    And thanks, i have ordered Silabs radio from Farnell Austria (the part number was the same) and it is on way to me .
    Feri
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by RipplingHurst View Post
    Quote Originally Posted by From the standardisation of plugins thread
    A set of example skin files should be provided preferably in either BMV2 or Carwings in the release thread (bmv2 PSD's are available in MP3car downloads section, Carwings PSD's are available in the Carwings thread)
    The above is a recommendation, it would be difficult to enforce (although I would like to) as we would probably have to remove a large percentage of them at the moment.
    Aug 2009
    Problems still with phone plugin
    RideRunner screen loading error!
    While loading: freefone.skin
    freefone.skin not found
    What is the best way to made working the phone plugin with standard RR installation?
    If i do run the standard installation exe, then i got this message. True - no phone installed. If i try to install Mobilephone.Net_setup1.14, then i got the same message again!
    PLEASE! What to do? I have found relative complicated way, but it is not a solution! A good - step by step - howto is needed. Or errorfree instalation routines - for RR and phone plugin. Lambosprit told me, that it is problem of RR and Carwings dynamic lite skin - not of phone plugin. So i like to know, if there is someone, that can give good guide to installation of phone plugin into standard instalation of Ride Runner! PLEASE! I and many others wish this info many times before and nobody can give answer?
    Thx,
    Feri
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Looks like the base Carwings dynamic lite skin is setup to use Freefone as it's phone plugin.
    You will need to change the phone references in exectbl.ini to Lambosprit's one.
    BTW pierrot77 has done a carwings skin for the plugin, but you will probably still need to change the button yourself
    Carwings_Dynamic_Lite Add_ONs
