Results 1 to 9 of 9
Thread: Have LSX 3.01 Skin Issue. (with pic)
    Low Bitrate cdcamaro9534's Avatar
    Nov 2005
    In the hills of Kentucky
    I've got an issue with the first screen with LSX 3.01. I could go into details, but I'll let the pic explain itself. Note that the other menus look ok, like audio, ect. Can someone tell me what might be going on. I've uninstalled and reinstalled with no luck.
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    VIA EPIA M10000 Mini-ITX Motherboard
    Iguidance GPS
    Road Runner Frontend w/ DFX5.0.3
    Xenarc 700IDT with DVD CDR/RW
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by cdcamaro9534 View Post
    looks like you need to install or upgrade to flash 10
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    Sep 2008
    Western Australia
    I had a similar issue to yours, Flash 10 was installed both for IE and Firefox, etc etc. Turns out it was because RR wasn't closed properly before opening a new instance. Check to see if you have two RR .exe's running, or I think I also deleted rr.ini before it finally stopped doing it
    Nov 2005
    Thanks for the reply guys, I haven't got to try anything yet cause I needed a cable to finish my install. Once it's here, I will give it a try.
    I'm sure I don't have two instances running, but I know flash 10 isn't installed. I'm sure this could be the issue.
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    Iguidance GPS
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'm unsure what version of RR you're running but I've seen this on OLDER versions of RR when you did not set a VALID background image for the skin to use (just a thought).
    Ride Runner RR's Myspace
    Nov 2005
    Ok I'm still having an issue. I've managed to get the skin kinda fixed by doing a complete uninstall, and reinstall. But I still have an issue with the white box at the bottom. I've installed Flash Player 10, but nothing changed.
    I did notice in the processes that both RideRunner.exe and RoadRunner.exe were running at the same time. But only one version of RR is installed on this PC. This is a complete new install with a fresh XP.
    I tried messing with the background images in RR Configure. But nothing changed. I even made sure both rr.ini and skin.ini were set the same as mentioned in a post I searched for earlier.
    While the skin works, I would like to have the white box gone. I'm clueless whats causing this right now.
    And this is RideRunner Version 10/6/09 if that helps.
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    Iguidance GPS
    Low Bitrate mrcanngo's Avatar
    Jun 2006
    Vancouver
    What version of winamp are you running?
    That kinda looks like the area that the visualization should be running. Can you try upgrading/downgrading to version 5.13
    Or try going (within the skins menus) to Options - Personalize - Main Menu and Vis Options - Select "Big Clock"
    And see if that helps?
    Just started playing with this skin so no idea if that'll help or not.
    Sep 2006
    War-Town, GA.
    @ 9534 that is absolutely a flash problem, install this one http://www.mp3car.com/vbulletin/road...sh-10-now.html or upgrade through the adobe site WITH INTERNET EXPLORER only.
    M2-ATX Power Supply
    Windows XP SP3
    Nov 2005
    Quote Originally Posted by treetop777 View Post
    I've already installed with this file. I've ran it a couple of times in fact. And the first time I installed flash before doing a format and reinstall, I used the internet and installed from Adobe's website.
    I've pretty much have given up in the issue. I have a few older LS skins that I ran in my Camaro. I'll probably revert back to one of those, cause they never gave me any problem. And I might toy around with a few other skins as well.
    As far as Winamp, I'm running 5.12. This is what I've ran in other installs with great success. I just don't see that being a Winamp issue.
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    Iguidance GPS
  1. LSX Void FAQ
    By ssteger in forum VaultWiki
    Last Post: 10-21-2009, 04:10 PM
  2. Replies: 0
    Last Post: 09-24-2009, 02:28 PM
  3. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  4. TEKNIK3 - Concept Skin
    By Valheru in forum RR Skins
    Last Post: 05-27-2008, 01:26 PM
  5. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
