Results 11 to 20 of 21
Thread: How to backup the front volume
  1. #11
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That is b/c BYVAR doesn't understand ON/OFF only true/false and numbers starting w/ zero.
    What i did was changed the ON=1, OFF=0 then byvar will now work.
    Here are the untested fixed lines...
    Code:
    /**************************************Twelve commands******************************************
    "MYCOMMANDS","BYVAR;$poi1cmd1$;<<poi1cmd1ON||BYVAR;$POI2CMD2$;<<POI1CMD1ON||BYVAR;$POI3CMD3$;<<POI1CMD1ON||BYVAR;$POI3CMD3$;<<POI1CMD1ON||BYVAR;$POI4CMD4$;<<POI1CMD1ON||BYVAR;$POI5CMD5$;<<POI1CMD1ON||BYVAR;$POI6CMD6$;<<POI1CMD1ON"
    "poi1cmd1ON","SAVETOSKIN;poi1cmd1;1||SETVAR;poi1cmd1;1||SETIND;!poi1cmd1;ON||ACTIVATEDCMD"
    "poi1cmd1OFF","SAVETOSKIN;poi1cmd1;0||SETVAR;poi1cmd1;0||SETIND;!poi1cmd1;OFF||DEACTIVATEDCMD"
    "poi2cmd1ON","SAVETOSKIN;poi2cmd2;1||SETVAR;poi2cmd2;1||SETIND;!poi2cmd2;ON||ACTIVATEDCMD"
    "poi2cmd1OFF","SAVETOSKIN;poi2cmd2;0||SETVAR;poi2cmd2;0||SETIND;!poi2cmd2;OFF||DEACTIVATEDCMD"
    "poi3cmd1ON","SAVETOSKIN;poi3cmd3;1||SETVAR;poi3cmd3;1||SETIND;!poi3cmd3;ON||ACTIVATEDCMD"
    "poi3cmd1OFF","SAVETOSKIN;poi3cmd3;0||SETVAR;poi3cmd3;0||SETIND;!poi3cmd3;OFF||DEACTIVATEDCMD"
    "poi4cmd1ON","SAVETOSKIN;poi4cmd4;1||SETVAR;poi4cmd4;1||SETIND;!poi4cmd4;ON||ACTIVATEDCMD"
    "poi4cmd1OFF","SAVETOSKIN;poi4cmd4;0||SETVAR;poi4cmd4;0||SETIND;!poi4cmd4;OFF||DEACTIVATEDCMD"
    "poi5cmd1ON","SAVETOSKIN;poi5cmd5;1||SETVAR;poi5cmd5;1||SETIND;!poi5cmd5;ON||ACTIVATEDCMD"
    "poi5cmd1OFF","SAVETOSKIN;poi5cmd5;0||SETVAR;poi5cmd5;0||SETIND;!poi5cmd5;OFF||DEACTIVATEDCMD"
    "poi6cmd1ON","SAVETOSKIN;poi6cmd6;1||SETVAR;poi6cmd6;1||SETIND;!poi6cmd6;ON||ACTIVATEDCMD"
    "poi6cmd1OFF","SAVETOSKIN;poi6cmd6;0||SETVAR;poi6cmd6;0||SETIND;!poi6cmd6;OFF||DEACTIVATEDCMD"
    "ACTIVATEDCMD","RRVolRamper_Dn;75;30||say;commande activée||RRVolRamper_Up"
    "DEACTIVATEDCMD","RRVolRamper_Dn;75;30||say;commande désactivée||RRVolRamper_Up"
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #12
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Code:
    I have tried these new lines.
    Only the first button run well with the indicator on/off and in the skin the good setup 0/1.
    For the five other buttons the setup (0/1) on the skin.ini is good , but the indicators don't run .
    And for each commands , when RR run it does not read the skin.ini file , also the indicators are off even if in skin.ini they are on 1 ?
    I have modified the first line :
    Code:
    by
    Code:
    "MYCOMMANDS","BYVAR;$poi1cmd1$;<<poi1cmd1ON||BYVAR;$POI2CMD2$;<<POI1CMD1ON||BYVAR;$POI3CMD3$;<<POI1CMD1ON||BYVAR;$POI4CMD4$;<<POI1CMD1ON||BYVAR;$POI5CMD5$;<<POI1CMD1ON||BYVAR;$POI6CMD6$;<<POI1CMD1ON"
    I don't know if i do that or not !
  3. #13
    May 2008
    Bordeaux, France
    Ok, I have found some little errors:
    I have modified the exectbl lines:
    Code:
    "MYCOMMANDS","BYVAR;$poi1cmd1$;<<poi1cmd1ON||BYVAR;$poi2cmd2$;<<poi1cmd1ON||BYVAR;$POI3CMD3$;<<POI1CMD1ON||BYVAR;$POI4CMD4$;<<POI1CMD1ON||BYVAR;$POI5CMD5$;<<POI1CMD1ON||BYVAR;$POI6CMD6$;<<POI1CMD1ON"
    "poi2cmd2ON","SAVETOSKIN;poi2cmd2;1||SETVAR;poi2cmd2;1||SETIND;!poi2cmd2;ON||ACTIVATEDCMD"
    "poi2cmd2OFF","SAVETOSKIN;poi2cmd2;0||SETVAR;poi2cmd2;0||SETIND;!poi2cmd2;OFF||DEACTIVATEDCMD"
    "poi3cmd3ON","SAVETOSKIN;poi3cmd3;1||SETVAR;poi3cmd3;1||SETIND;!poi3cmd3;ON||ACTIVATEDCMD"
    "poi3cmd3OFF","SAVETOSKIN;poi3cmd3;0||SETVAR;poi3cmd3;0||SETIND;!poi3cmd3;OFF||DEACTIVATEDCMD"
    "poi4cmd4ON","SAVETOSKIN;poi4cmd4;1||SETVAR;poi4cmd4;1||SETIND;!poi4cmd4;ON||ACTIVATEDCMD"
    "poi4cmd4OFF","SAVETOSKIN;poi4cmd4;0||SETVAR;poi4cmd4;0||SETIND;!poi4cmd4;OFF||DEACTIVATEDCMD"
    "poi5cmd5ON","SAVETOSKIN;poi5cmd5;1||SETVAR;poi5cmd5;1||SETIND;!poi5cmd5;ON||ACTIVATEDCMD"
    "poi5cmd5OFF","SAVETOSKIN;poi5cmd5;0||SETVAR;poi5cmd5;0||SETIND;!poi5cmd5;OFF||DEACTIVATEDCMD"
    "poi6cmd6ON","SAVETOSKIN;poi6cmd6;1||SETVAR;poi6cmd6;1||SETIND;!poi6cmd6;ON||ACTIVATEDCMD"
    "poi6cmd6OFF","SAVETOSKIN;poi6cmd6;0||SETVAR;poi6cmd6;0||SETIND;!poi6cmd6;OFF||DEACTIVATEDCMD"
    Now all commands run well with the indicators , but the setup in the skin.ini are not read when RR run and the indicators are always off , but if i push on a button who are = 1, if see it and set it = 0 and run well the command DEACTIVATEDCMD .
  4. #14
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Try...
    I forgot to remove the "$" after i converted it..sorry...
    Code:
    "MYCOMMANDS","BYVAR;poi1cmd1;<<poi1cmd1ON||BYVAR;poi2cmd2;<<poi1cmd1ON||BYVAR;POI3CMD3;<<POI1CMD1ON||BYVAR;POI4CMD4;<<POI1CMD1ON||BYVAR;POI5CMD5;<<POI1CMD1ON||BYVAR;POI6CMD6;<<POI1CMD1ON"
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #15
    May 2008
    Bordeaux, France
    Smile
    Try...
    Code:
    Ok , Thanks Blue, i try that today and say you if it is good .
    I try to create a screen for the Carwings Add Ons with twelve commands on/off .
    I don't know if it is a good idea and if the RR's community will use it .
    Use it with serialswitch or rrvoicecontrol, or to run any command , RR or windows is a good add on, i think .
    I try that .
    May 2008
    Bordeaux, France
    Try...
    Code:
    I am sorry Blue this new command don't run for each command .
    The preceding version functioned well but don'r read the skin.ini when RR run .
  7. #17
    May 2008
    Bordeaux, France
    Talking
    I am sorry Blue, i am certain that you are very busy, but if you have a solution for my problem ?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I can check this out when I get home today from work, to see where the issue is. Could you zip up just the screen files that this is using to assist in getting this finally corrected.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #19
    May 2008
    Bordeaux, France
    Thanks Blue again.
    This is my files . My work are not finished .
    In the blue rectangle, the commands who don't read the skin status .
    In the yellow rectangle, is an example that i should like to have for the 6 commands who are in the blue rectangle.
    On the first button, i have mixed the blue and yellow possibility .
    With that , i have two toggled commands on one button .
    My lines are not optimized , i think , also if you have a better solution ?
    In the orange rectangle, i should like to see the same picture that the button i use .
    That i should like is when i push on a button , the button's image is seen on the right top window.
    After this screen , i think to create a little autoit program who detect a gps position , as the Speedzone plugin . But i want also run or to kill 12 exe and 12 RR command .
    I don't understand why i can't run a RR command like GPSEXEC .
    I have the same problem in general when i create an alias, like that :
    Code:
    "GPSEXEC","RUN;$rrpath$Plugins\GPSExec\GPSExec.exe"
    If i add that on my "MyApp81","" :
    Code:
    "MyApp81","GPSEXEC"
    This command don't run, i must use that:
    Code:
    "MyApp81","RUN;$rrpath$Plugins\GPSExec\GPSExec.exe"
    Thanks for your help Blue
    Attached Files Attached Files
  10. #20
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Not sure bout what you just added, but I did work some work on the other part. Not only got it working but improved it.
    Hopefully I'll finish what I couldn't get to today tonight and post up what I have.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Hardware Review: JL Audio CL-RLC volume controlled preamp
    By soundman98 in forum The Review Palace
    Last Post: 06-12-2011, 09:30 PM
  2. Volume / Definition Issues
    By bratnetwork in forum Car Audio
    Last Post: 10-22-2009, 07:58 PM
  3. RR volume mapping
    By kaerf in forum RR Bug Tracker
    Last Post: 08-13-2009, 04:56 AM
  4. volume issues
    By warnockm in forum Road Runner
    Last Post: 08-10-2008, 12:04 AM
  5. VIA smart 5.1 super LOW front volume
    By tibby01 in forum Car Audio
    Last Post: 10-17-2006, 01:40 PM
