Results 1 to 6 of 6
Thread: Slider images
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Slider images
    I am trying to use 2 different sets of images for separate sliders. One set for battery in TPMS and one set for sat signal in XM. I cannot seem to be able to get both to work. It is one or the other. Which ever images are in the SLIDER_BATTERY folder are the images are used. I tried specifying a path to the correct images but RR continues to use the images in the SLIDER_BATTERY folder.
    I tried this for a folder named slider_XM and the gif images inside it. Also tried slider_signal. The folders are in the skin folder of the selected skin.
    Code:
    "slider_XM\slider_*.gif"
    Any help would be appreciated.
    I am using the January version of RR (1/1/2010)
    running Carwings Lite skin
    Windows 7 64-bit and 32-bit
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    May 2005
    Lawrenceville GA
    I have the images in the skin folder I am using. (Sorry posted wrong location before. fixed)
    with this skin code.
    XM skin
    Code:
    S03,5,84,49,20,62,103,70,20,H,01,"slider_signal\slider_*.gif",015,"XMSAT","Sat Signal"
    TPMS skin
    Code:
    S01,559,77,47,34,559,77,47,34,H,01,"",0,"TMS_BATTERY_RR",""
    Both lines display the same set of images from the slider_battery folder
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Do you not have any Y lines just before the sliders
    ie
    Y01,"slidermusic\slider_*.gif"
    because it's that line which specifies which images to use.
    the path part of the S line is just for the pointer location.
    May 2005
    Lawrenceville GA
    Quote Originally Posted by Enforcer View Post
    ie
    I added this
    Y01,"slider_battery\slider_*.gif"
    With the same results. It uses the images in the folder named SLIDER_BATTERY. I am sure I am doing something wgong just not sure what.
    May 2005
    Lawrenceville GA
    I got it. I took the reference to the slider images out of the S line and it works now. Thank you for your help!!
  1. Slider Help
    By neanderthalman in forum RR Skins
    Last Post: 12-17-2009, 07:41 PM
  2. Skin Problem
    By riko in forum RR Skins
    Last Post: 07-16-2009, 02:50 AM
  3. Retreiving Custom SLider value help needed
    By JohnWPB in forum Road Runner
    Last Post: 02-21-2008, 05:24 PM
  4. Volume Slider
    By garto in forum Road Runner
    Last Post: 05-13-2007, 01:11 PM
  5. Access 2003 help needed
    By veedubya in forum Off Topic
    Last Post: 05-31-2006, 07:49 PM
