Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Making Overlay stay on TOP of application
  1. #11
    Jun 2007
    St. Louis
    Quote Originally Posted by guino View Post
    Sorry, I gave you those links because on a previous post you mentioned putting Garmin in the embedded list on RRConfig -- which is not the place to set it up. From looking at your last post, the same lines used for carwings should work the same on elite skin AS LONG AS you have GMPC.skin, GMPCOL.skin, GMPCOSK.skin AND ElcosMenu.exe ALL in the Elite skin folder. If anything, try making a debug log on carwings to see exactly what's being executed, then compare it to what's being executed in the Elite Skin -- that way you'll have something to tell you what's missing.
    yes, I included those snippets from the original carwings and original elite skins for reference. When I make changes to my testing area, I utilize the garmin1.png and similar files and their respective paths within the Elite skin.
    I'll make the debug log - hadn't thought of that - thanks
  2. #12
    Oct 2009
    Any luck with this? I've been trying to do the exact same thing but have the same problem!
  3. #13
    Jun 2007
    St. Louis
    I gave up and went back to Carwings. I didn't have the time to invest into getting it to embed right with Elite Lite. Love the skin, looks super.
    I tend to use iGo8 these days though to see how it works...haven't tried that in Elite Lite yet.
  4. #14
    Oct 2009
    I finally managed to figure it out! I actually got it not long after posting the other day, but wanted to finish it up before replying. Basically I think for your case, in your ExecTBL, change "GARMIN",... to "GPS",... This is what's called when you press the Garmin button, and if you overwrite the GPS command it will skip external_gps.skin. There's probably a little more involved but you can check out my post: http://www.mp3car.com/vbulletin/rr-s...een-elite.html to download what I've done. ElcosMenu is a tricky beast...
  1. Replies: 118
    Last Post: 03-19-2010, 08:07 PM
  2. Replies: 7
    Last Post: 04-06-2009, 05:14 PM
  3. Making dashcam application with speed overlay.
    By Maheriano in forum Software & Software Development
    Last Post: 06-18-2008, 01:49 AM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  5. How to embbed any Application in RR ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 01:35 PM
