Results 1 to 10 of 14
Thread: Making Overlay stay on TOP of application
    Jun 2007
    St. Louis
    I'm trying to use the Elite Lite skin, and wanted some more screenspace for Garmin so I started messing around with it. I've got the png, and skin file the way I want...but for whatever reason when it loads, Garmin stays on top of the skin, not embedded beneath it. In Carwings it works just fine...but Elite Lite it doesn't.
    I've compared skin files from Elite Lite to Carwings, and they look similar with regards to the buttons and whatnot, but am I missing something somewhere? Is there a setting in the skin or Garmin.Elite file which tells it to keep the overlay on top of Garmin?
    here's a screenshot:
    By nst6563 at 2010-02-10
    I've searched around a bit and haven't come across anything to solve it yet. Read the skinning tutorial as well. I'm new to messing with the skins so any assistance would be greatly appreciated.
    Thanks in advance
    Jun 2007
    St. Louis
    Here is the garmin.elite file:
    Code:
    IMG,0,0,800,480,"$skinpath$\garmin1.png",OFF
    IMG,0,0,800,480,"$skinpath$\garmin1-down.png",DOWN
    B,754,424,86,56,"X_OVERLAY||WAIT;0.2||GMPCOSK",
    B,713,424,86,56,"EXIT",
    A,0,0,800,480
    Here is the garmin.skin file:
    Code:
    RoadRunner Skin
    RRScreen garmin
    A,0,0,800,480
    /KEEPLOADED
    GMPC_OVERLAY
    /POSX=000
    /POSY=000
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    L04,242,2,557,26,255,255,255,22,"HandelGotDLig","TAGARTIST||= - ||TAGTITLE","SCROLL-LEFT"
    /Play Buttons
    B,-1,440,45,41,"PREV",
    B,46,439,60,42,"PLAY",
    B,109,440,56,40,"NEXT",
    B,626,424,86,56,"X_OVERLAY||WAIT;0.5||GMPCOSK",
    B,713,423,86,56,"X_OVERLAY||EXIT",
    END
    I messed with the A,x,y,h,w line and can change the size of the Garmin screen, and ideally I'd like it to be the full 800x480 with the overlay on top (like in Carwings)...however i can't seem to get it to work.
    If I do nothing else but change the skin to Carwings, it's embedded correctly. So I take it I need to specify the Application name in the Elite Lite skin someplace? I haven't found it yet, but maybe I'm just not looking in the right places. I can post up the Skin.ini and Exectable.ini files but they should be the stock Elite Lite files. The only files I've changed were the garmin.elite and garmin.skin files.
    thanks for the help
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well the A line you are showing me should put the Garmin in the top left of the screen.
    As it doesn't I suspect that the position and size of the Garmin screen is set in the Garmin settings.
    Also it would indicate that the Garmin application isn't truly embedded, but just running on top of RR.
    Jun 2007
    St. Louis
    In RRConfig I've set Garmin as one of the embedded applications. This would be the correct place right?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ride Runner RR's Myspace
    Jun 2007
    St. Louis
    I've read those before, and have again to make sure I wasn't missing something, same problem. The only skin I have a problem with Garmin embedding is Elite Lite.
    Like I've said before - if I use Carwings, it embeds like it should, when I use Elite lite it doesn't. Do I need to add those lines to the Elite Lite skin.ini as well?
    I don't know enough about skinning to know if/how variables are passed between the application ini and skin ini. My assumption is that the application ini variables are of a global type and ones in the skins are private, but the skin inherits the application variables - but that's just an assumption.
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    the commands for embedding garmin are in exectbl.ini. check your skin's exectbl.ini against the one from carwings.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
    Jun 2007
    St. Louis
    Quote Originally Posted by kuo View Post
    I've been trying some different things this morning while waiting for scripts to finish at work, here is the code I've been comparing and messing with
    Code:
    /--------------------Original--GARMIN--Elite Lite----------------
    /"GMPC_OVERLAY","RUN;$SKINPATH$support/ElcosMenu.exe|garmin.skin"
    /"GMPCOSK","RUN;$SKINPATH$support/ElcosMenu.exe|garminosk.skin"
    /"X_OVERLAY","SENDMSG;ElcosMenu;Exit"
    /"GARMIN","GPS||GMPC_OVERLAY"
    /--------------Testing---GARMIN---Testing---------------------
    "GMPC_OVERLAY","RUN;$SKINPATH$support/ElcosMenu.exe|garmin1.skin"
    "GARMIN","LOAD;garmin1.skin||RUN;$SKINPATH$ElcosMenu.exe|garmin.skin||RUN;$garminpath$;!CDP"
    / Garmin from Carwings
    /"MyApp15","LOAD;GMPC.skin||RUN;$SKINPATH$ElcosMenu.exe|GMPCOL.skin||RUN;$garminpath$;!CDP"
    /"GMPC_OVERLAY","RUN;$SKINPATH$ElcosMenu.exe|GMPCOL.skin"
    /"GMPCOSK","RUN;$SKINPATH$ElcosMenu.exe|GMPCOSK.skin"
    /"GMPC","LOAD;GMPC.skin"
    /"RUNGMPC","RUN;$garminpath$;!CDP",GMPC.skin
    It doesn't seem to matter what I change, Garmin ALWAYS appears on top in the Elite Light Skin. I really like the Elite Lite...but if I can't get Garmin embedded and be able to run both Garmin and iGuidance at the same time in it - I'll go back to Carwings or DFX.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Sorry, I gave you those links because on a previous post you mentioned putting Garmin in the embedded list on RRConfig -- which is not the place to set it up. From looking at your last post, the same lines used for carwings should work the same on elite skin AS LONG AS you have GMPC.skin, GMPCOL.skin, GMPCOSK.skin AND ElcosMenu.exe ALL in the Elite skin folder. If anything, try making a debug log on carwings to see exactly what's being executed, then compare it to what's being executed in the Elite Skin -- that way you'll have something to tell you what's missing.
  1. Replies: 118
    Last Post: 03-19-2010, 08:07 PM
  2. Replies: 7
    Last Post: 04-06-2009, 05:14 PM
  3. Making dashcam application with speed overlay.
    By Maheriano in forum Software & Software Development
    Last Post: 06-18-2008, 01:49 AM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  5. How to embbed any Application in RR ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 01:35 PM
