Results 21 to 30 of 37
Thread: Run an embedded program with option found in a list
  1. #21
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I just tried the command here and it works as you can see on this screenshot. I can only assume that you're not using the LATEST version of RRExtended.
    However, if StrMid works on your version, then you can try this instead:
    Code:
    B,258,428,272,85,"SETVARBYCODE;FP;LISTTEXT||RRSTRINGS_STRLEN;FP;FLEN||EVAL;FLEN;$FLEN$-4||RRSTRINGS_STRMID;FP;1;$FLEN$;FP||LOAD;finalburnergame.skin||RUN;C:\Program Files\Ride Runner\Skins\Carwings_Dynamic_pm\FinalBurn Alpha\fba | "$finalburnerpath$$FP$"";FB Alpha v0.2.97.08"
    Ride Runner RR's Myspace
  2. #22
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    It's better for me but not run again.
    My last command is that:
    Code:
    B,258,428,272,85,"SETVARBYCODE;FP;LISTTEXT||RRSTRINGS_STRLEN;FP;FLEN||EVAL;FLEN;$FLEN$-4||RRSTRINGS_STRMID;FP;1;$FLEN$;FP||LOAD;finalburnergame.skin||RUN;fba $FP$;FB Alpha v0.2.97.08"
    because final burner don't accept the path before it.
    I i create a run.bat file and put in, fba sf2, it run the good rom because the path is already defined in the final burner ini file.
    My issue now is if i launch the command without the rom name, here $FP$, final burner is well launched but without the rom (it's normal!), but if i add the rom name,($FP$) , final burner are not launched
  3. #23
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Instead of:
    Try:
    RUN;fba|$FP$;FB Alpha v0.2.97.08
  4. #24
    May 2008
    Bordeaux, France
    I have try that:
    Code:
    B,258,428,272,85,"SETVARBYCODE;FP;LISTTEXT||RRSTRINGS_STRLEN;FP;FLEN||EVAL;FLEN;$FLEN$-4||RRSTRINGS_STRMID;FP;1;$FLEN$;FP||LOAD;finalburnergame.skin||RUN;fba | $FP$;FB Alpha v0.2.97.08"
    and the skintool give me:
    Code:
    setvar;FLEN;0
    EVAL;FLEN;0-4
    RRSTRINGS_STRMID;FP;1;-4;FP
    Command Not Executed: RRSTRINGS_STRMID;FP;1;-4;FP
    RUN;fba | ;FB Alpha v0.2.97.08
    and if i try that:
    Code:
    B,258,428,272,85,"SETVARBYCODE;FP;LISTTEXT||RRSTRINGS_FILEFROMPATH;$FP$;LISTTEXTFILE||LOAD;finalburnergame.skin||RUN;fba | $LISTTEXTFILE$;FB Alpha v0.2.97.08"
    Code:
    RRSTRINGS_FILEFROMPATH;Sfiii3a.zip;LISTTEXTFILE
    Command Not Executed: RRSTRINGS_FILEFROMPATH;Sfiii3a.zip;LISTTEXTFILE
    ONSCREENCHANGE
    RRextended RRstrings commands return a name with a upcase Sfiii3a.zip and not sfiii3a.zip that final burner want.
    i shall want to create a run.bat with the WRITETOFILE command and to replace the fba $FP$ command by the run.bat, but that don't run.
    Code:
    WRITETOFILE;C:\Program Files\Ride Runner\Skins\Carwings_Dynamic_pm\Emulators\FinalBurn Alpha\run.bat;=fba $FP$
  5. #25
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have no other solutions. The writetofile will not work because the $FP$ variable isn't being set correctly (because RRStrings_Strlen and RRStrings_Strmid are NOT working). All I can tell you is that there's something wrong with your RRExtended -- either it's not loaded or it's not the latest version (1.1.5). If you make RRExtended to work, then all 3 solutions posted will work.
  6. #26
    May 2008
    Bordeaux, France
    I have already uninstalled RRextended and reinstall it .
  7. #27
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You may want to load the plugin manager and see what version it shows for the RRExtended plugin -- you may have more than one version on the machine ?
    You can also try to execute the same commands on the screenshot I posted to see if they work.
  8. #28
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    After trying this cmd here too, I got same bad cmd not execuded..bla..bla
    So after looking at code...you need to remove the "$" from the supplied var in the cmd as it will get it from rr when it processes it.
    "RRSTRINGS_FILEFROMPATH;FP;LISTTEXTFILE"
    Is the correct command that your looking for. I will add in future ver that if it gets no return from the var via a var or label then it will just use supplied text which would have then worked as you have tried to use as..
    Sorry for the inconsincess of RR's var "$xx$" syntax and RRExtended!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #29
    May 2008
    Bordeaux, France
    With that command line:
    Code:
    B,258,428,272,85,"SETVARBYCODE;FP;LISTTEXT||RRSTRINGS_FILEFROMPATH;FP;LISTTEXTFILE||LOAD;finalburnergame.skin||RUN;fba | $LISTTEXTFILE$;FB Alpha v0.2.97.08"
    my skintool log give me that:
    Code:
    load;emu_console.skin
    ONSCREENCHANGE
    ONBTNPRESS
    LOAD;finalburner.skin
    ONSCREENCHANGE
    ONDIRCLICK
    ONFILECLICK
    ONBTNPRESS
    Command Not Executed: RRSTRINGS_FILEFROMPATH;FP;LISTTEXTFILE
    ONSCREENCHANGE
  10. #30
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I will also mention that the notes fail to mention that the var its looking for is in the form of a path, the current version will not take just a file name as you have here. I have fixed/added support for file only if no path supplied.
    So to make it work with current your going to need to put a path break in there too..eg
    Code:
    "SETVARBYCODE;FP;LISTTEXT||SETVAR;FP;\$FP$||RRSTRINGS_FILEFROMPATH;FP;LISTTEXTFILE||LOAD;finalburnergame.skin||RUN;fba | $LISTTEXTFILE$;FB Alpha v0.2.97.08"
    Enjoy
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  2. Found this list of every OBDII thing out there
    By Skipjacks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-27-2005, 05:50 PM
  3. Replies: 9
    Last Post: 01-19-2005, 10:52 AM
  4. Replies: 2
    Last Post: 06-12-2003, 09:13 AM
