Results 1 to 10 of 15
Thread: New Garmin Screen for eLite
    Oct 2009
    After much frustration I've finally got a Garmin skin I can live with for awhile! I'm pretty much "stuck" (although I do like it!) using eLite because I have the Lilliput/Intel combo where I just cannot get 800x480 to display, so I have to use an 840x480 skin stretched to 800x600 stretched back to 800x480! eLite is the only one I've found where I can get actual circles! However, the various overlays for Garmin give you about half of the screen for the GPS! Since that's the primary display I use, this is what I've come up with.
    This was modified from both the "eLite patch2" as well as tommy_xx84's garmin screen. I couldn't implement all of the things I wanted because ElcosMenu just doesn't support everything. The artist and title are not centered so look a little goofy because only left-justification is supported. There is a timer that runs that may cause cpu usage to creep up because that is the only way to get the clock to update.
    I originally had the gps window a little bigger by cutting off the bottom of Garmin, but it turns out you can only cut off about 5-10 pixels from the bottom (Garmin just won't let you move it off the screen!). So I added a little more flair through the bottom screen.
    This skin works for 800x600 as well as if you run "originalheight=480/showheight=600". I'm not sure if it'll work in strictly 480. I think it'd be somewhat simple mods though...resize the graphics to 800x480 and then adjust the vertical placement of everything. Again, unfortunately ElcosMenu doesn't support screen stretching it seems.
    The ExecTBL bypasses the builtin "GPS" and external_gps.skin. The two requirements are ElcosMenu in your "support" directory and you may have to add "garminpath=" in the GPS section to rr.ini.
    Attached Files Attached Files
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    I was in the same boat as you for a while with the streching to squishing on the elite skin. I figured mine out on an ION board. But, I remembered seeing this:
    http://www.mp3car.com/vbulletin/lcd-...-graphics.html
    It might help. Good luck, my friend.
    You are never done installing a CarPC.
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    I'm definitely going to have to try this when I get a chance. I really like the elite lite skin and I've been working on fixing the Garmin issue, but I just haven't had the time. This one looks like it will work well for me. I'll let you know how it works out for me when I get around to testing it.
    Aug 2009
    Virginia
    Excellent. Glad I could help point you in the right direction! And believe me, getting your screen running in native is just like getting a new one; at least that's how I felt!
    Jun 2007
    St. Louis
    w00t! Gonna try that this weekend
    I gave up on Garmin with Elite but I may switch back now. Of course... now I like iGo8 better than Garmin so go figure
    Oct 2009
    Spikemonkey,
    I've tried all of that with no luck. Which method did you use? DTD strings?
    Oct 2009
    nst6563,
    How are you running igo8? All I can find is a pda app. Are there US maps available?
    Oct 2007
    Haledon, NJ
    Works good for me!
    Aug 2009
    Virginia
    Quote Originally Posted by bratnetwork View Post
    Works good for me!
    Yay!
    Aug 2009
    Virginia
    Quote Originally Posted by olevelo View Post
    Spikemonkey,
    No, read here to see what I did:
    http://www.mp3car.com/vbulletin/lcd-...ml#post1375032
    I hope it helps.
  1. My custom motorized screen plan
    By PatDaRat in forum Fabrication
    Last Post: 03-12-2010, 03:41 AM
  2. My Motorized screen plan
    Last Post: 03-01-2010, 10:42 AM
  3. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 11:56 AM
  4. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
  5. Replies: 11
    Last Post: 01-31-2006, 04:37 AM
