Results 1 to 10 of 12
Thread: Skin question about dual display and GPS
    May 2005
    Monterey, CA
    Question Skin question about dual display and GPS
    I am messing around with the possibility of making a dual display skin. For now I am taking an existing skin, in this case carwings, and trying to expand the main menu to include the gps to the right of it.
    How do I go about getting RR to load the GPS app on the main menu so I can embed it? I have it working on the gps skin, where it embeds it on the 2nd display. But is there a way to do it on the main menu? I have the application area defined, but can't figure out how to get it to load the app so that it will embed.
    Any ideas?
    Thanks, I really would like to get this working I think it will work out.
    I was thinking of on each skin to have the gps to the right of it, except for the gps skin where it would embed normally so I can control it.
    Does that makes sense? Is that possible?
    FKA psptibby
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    should be possible and some have done it in the past.
    If you want it to auto-load the GPS on the main menu, you should load it using the ONSKINSTART event.
    Once you have defined the application area, you should use the run command to start the gps and define the window title to embed:
    "RUN;c:\gps\gps.exe;GPS Window"
    Ride Runner RR's Myspace
    May 2005
    Monterey, CA
    Thanks I will play around with that. Is there anyway to just use the values from the config file instead of hard coding it?
    FKA psptibby
    guino's Avatar
    Nov 2004
    Toronto, Canada
    sure, all settings in RR are accessible as variables:
    you can do something like:
    "RUN;$GPSPATH$;$GPSNAME$"
    May 2005
    Monterey, CA
    Great, thanks so much. So the RUN goes on the ONSKINSTART and then define that app area. I have app area defined already. So a matter of adding ONSKINSTART with the run command. So I was using load that was my problem.
    I hope to try this tonight, I am really excited, have wanted this for a long time.
    On a side note, The images use transparency right? Like in carwings for the middle area in the generic skin?
    FKA psptibby
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by bay350z View Post
    most newer skins use transparency.. however when embedding an application the skin will stay behind the application's window.
    May 2005
    Monterey, CA
    So the RUN command worked much better. The problem I am having now is when I switch back to the main screen the gps screen doesn't show. Looks like it is locking to the gps skin because when the gps shows on the main screen it doesn't embed nicely, it shows the menu bar and stuff. When I switch to the gps skin that stuff goes away and looks embed properly [EDIT] and stays that way in the other screens if I use the workaround below. [/EDIT]
    Does that make sense?
    EDIT: I changed the back buttons to this
    B,675,4,119,59,"LOAD;menu.skin;$gpsname$;$gpspath$ ;$gpsname$",
    Instead of
    B,675,4,119,59,"exit",
    What is the difference? Is the exit a builtin command? If so I can get it work using that?
    FKA psptibby
    guino's Avatar
    Nov 2004
    Toronto, Canada
    EXIT is a built in command. It HIDES any embedded application and returns to the previous (Caller) screen.
    Which GPS application are you using ? iGuidance ? if so, the "iGNative" option (which makes several tweaks to the application) could be the issue -- because it was made to work on the GPS screen only. I can't see why it would work any differently for any other GPS application.
    May 2005
    Monterey, CA
    Yeah i am using iguidance. I was looking at DFX for examples and it uses "EXITMENU" is that the same as "EXIT"?
    What do you mean by using iGNative? You mean in the rr.ini? Thats enabled.
    Replacing all exit to the load;skin;gps works. but that probably isn't the cleanest way.
    FKA psptibby
    May 2005
    Monterey, CA
    Is there any differance loading the audio player using the load;skin vs just using the AUDIO command?
    FKA psptibby
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 07:22 PM
  2. Dual Monitor Help (GPS to 2nd display)
    By bay350z in forum Road Runner
    Last Post: 08-31-2010, 01:51 AM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 12:23 PM
  4. Dual Display Solved - 2 programs, 2 screens
    By Nstyle in forum LCD/Display
    Last Post: 09-07-2007, 08:37 PM
  5. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 05:54 AM
