Results 1 to 10 of 10
Thread: "BACK" command and Directory Listing
    Aug 2004
    Southern California
    I noticed that a directory listing of the music path, will not allow you to use the "BACK" command to browse to the directory before your specified music folder. For example if my music path is c:\media\music, I won't be able to use the "BACK" skin command to get to c:\media\
    I want to use this type of limitation for my playlist directory listing. I am using the following code in my skin to open my playlists in my audio browser:
    Code:
    B07,503,241,210,85,"Load;AUDIO_BROWSER.skin||SETPATH;$PLAYLISTPATH$",
    The audio browser opens the directory just fine, and I am in the correct playlist folder, but I can still use the "back" button to browse all the way to the root (c:\). I just want to prevent this from happening so my wife won't get confused if she is looking for playlists. Thanks
    MySQL Error
    Oct 2004
    maybe
    pathlimit=true in rr.ini
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2004
    Southern California
    Thanks Mitch,
    I'll take a look at that setting. BTW I'm using your cable for my HD Radio! Thanks
    Aug 2004
    Southern California
    So I checked that setting, and its already set to true. I think it only applies to the music path? I changed it to false, and sure enough when I browse in the music folder, I can back up all the way to root.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You should be able to use this type of limitation by specifying the path using the SD definition -- It will only limit if Pathlimit=true. SETPATH is just not limited in any way, so it will allow you to do anything you want and go anywhere you want.
    Ride Runner RR's Myspace
    Aug 2004
    Southern California
    Thanks Guino,
    The audio browser skin I'm using (Reborn / BMW E36) uses an ilist to show the directory listing, could that be the reason? How would I set this limitation in an ilist, when I specify the playlistpath? Thanks
    Aug 2004
    Southern California
    Thanks Mitch and Guino,
    The new version's ;lock command for setpath works great, It now works the way I need it to work.
    MySQL Error
    Oct 2004
    you're welcome
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Constant Bitrate toyotatyrant's Avatar
    Aug 2007
    Hampton Roads VA
    Quote Originally Posted by All4Sky View Post
    I second that. It's one of the best and most practical features that has EVER been added to Riderunner.
    ATTENTION FELLOW CAR PC ENTHUSIASTS, POWER ACOUSTIC = CAR PC KRYPTONITE!!!! AVOID AT ALL COSTS!!!!
    To my adoring fans, No my Toyota's gas pedal didn't get stuck! Instead I saw you crossing the street and decided to floor it! Unfortunately, I MISSED!!!
    Aug 2008
    Hi
    Is there any chance to make Dvd library(dvd_browser.skin) and Picture library(picviewer.skin) Limited also?
    It doesnt work with pathlimit=true in rr.ini or maybe i have missted something
