Results 1 to 7 of 7
Thread: RR/DFX4 Gauges Stats?
    Feb 2005
    Hi, I'm new to RR planning on switching over from Media Engine. I am using DFX4. I got all the buttons and menu setup the way I want but I am still having a problem.
    I can't seem to get GAUGES STATS to work. Can anyone tell me how to get the satellites and speedo to work with my gps?
    Currently connected through bluetooth. Detectable and connected through both Windows XP and Garmin Mobile PC. Where and what files do i have to alter to setup the com port for Gauges Stats?
    Second thing is, which plugin works for Blackberry phones? At least the basic dial/answer through bluetooth.
    Thank you,
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Are you using some kind of GPS com port splitter, like XPORT ?
    If not you need to set up the physical port to XPort, and then virtual ports for RR / DFX and for your GPS program.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    Feb 2005
    Ok, i now got xport... now what?
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Run Xport. I believe it sets itself up to run automatically on startup from now on.
    Set your GPS port on the left side to your actual physical port. Then set up the right side to connect to your GPS program and RR.
    For example port 3 for the physical port, and 4 and 5 for your GPS and RR. Then Set your GPS program to port 4 and in RR Config set RR to port 5.
    Feb 2005
    ah ic ic, but, where do i set the RR gps port? i didnt see it in rrconfig
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    it'll be in the rrconfig
    under the GPS section - under the 'Other' portion
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    Feb 2005
    sweet! thanks! got it working now!
  1. gauges on multiple screens?
    By mattnsac in forum DashCommand
    Last Post: 08-22-2009, 01:53 PM
  2. Replies: 2
    Last Post: 02-23-2009, 03:49 PM
  3. Flash based gauges?
    By stonestatue in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-27-2008, 03:56 PM
  4. aftermarket gauges installation
    By 3square in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-07-2008, 11:33 PM
  5. G Series Vans Look here. DASH GAUGES (BACKLIT)
    By ChevyG20SS in forum General Hardware Discussion
    Last Post: 09-12-2007, 02:12 AM
