You'll have to do a conversion from the 0-500 range into the 0-65536 range.. you just set:
DISTANCESLIDER = $DISTANCE * 137.05 ( 65536/500 = 137.05 or 500 steps of 137.05)
Then you just do SETVAR with the DISTANCESLIDER value.
Hello all,
I try to undertand how the slider run with autoit.
Into my screen , i have these lines:
I look for an autoit example , how to program .Code:/Slider verticaux Y02,"DistanceSliderImages\SLIDER_*.png" S02,185,316,35,223,545,75,35,30,V,02,"",015,"!DISTANCESLIDER",""
If i understand the variable must to go from 0 to 65536
So, if my autoit is $distance and go from 0 to 500 (by example)
What i do to write .
Thanks for all help !![]()
Ride Runner RR's Myspace
Who can say me why $rr.getinfo("isunits") don't return me True or False?
Thanks![]()
"isunits" is a variable/setting not a label code, so you should use: $rr.getinfo("=$isunits$")
for the slider, you need to define a variable slider like:
THEN you can use SETVAR with it:Code:/Slider verticaux Y02,"DistanceSliderImages\SLIDER_*.png" S02,185,316,35,223,545,75,35,30,V,02,"",015,"$DISTANCESLIDER$",""
$rr.execute("SETVAR;DISTANCESLIDER;10000")
$rr.execute("SETVAR;DISTANCESLIDER;"&$distance * 137.05 )
