Results 1 to 7 of 7
Thread: VISU when switching screens
    Variable Bitrate Deric's Avatar
    Sep 2006
    While debugging nGen, I noticed if I have a visualization on one screen (MP3 for example) and switch to another screen with the visualization (Radio in this case) that I have to toggle the VISU command off and back on. Once I do this if I switch screens back and forth it works correctly without the toggle. Is this by design? Is there a way to show the visualization without cycling the visu command initially?
    Sep 2006
    Here is a video showing the issue.
    Attached Files Attached Files
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Same issue for me !
    On screen change, the visu don't follow the new screen, i need to use the command visu twice.
    MySQL Error
    Oct 2004
    not if you properly declare a visu window
    super secret skin def command
    taken from carwings_dyanamic_lite's audio.skin
    [ Visualization Window]
    Z,1,74,797,467,
    placing that in a .skin file will preload the visuname
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Sep 2006
    WOOHOO - Thanks Mitch! This works so much better than the workaround I had.
    Quote Originally Posted by mitchjs View Post
    Z,1,74,797,467,
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    hehehe... if there's a def. it should prob. be in the doc... another way was to use the infamous "run;;$visuname$" command when loading the screen.
    Ride Runner RR's Myspace
    May 2008
    Bordeaux, France
    Smile
    Secret def ? It's abnormal !!!
    It's ok also for me.
  1. Dual Display Solved - 2 programs, 2 screens
    By Nstyle in forum LCD/Display
    Last Post: 09-07-2007, 08:37 PM
  2. FAQ: Technical Terms regarding Screens
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-25-2006, 05:04 PM
  3. Headrest screens look rough and video will not show
    By jac1502 in forum LCD/Display
    Last Post: 06-10-2006, 09:38 PM
  4. Multiple Screens? Larger Screens?
    By Atom_Bomb in forum LCD/Display
    Last Post: 03-31-2004, 06:24 PM
  5. 2 screens...possibly some other stuff..
    By SuperMatty in forum Classified Archive
    Last Post: 08-18-2002, 01:20 PM
