Results 1 to 7 of 7
Thread: Visu with winamp 5.58
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile Visu with winamp 5.58
    On the councils of JohnWPB, i use now the last winamp version (5.58) with RR.
    And now the visu is very well embedded ! It's very cool .
    But, with my WebRadio script, the levels stay always down .
    I think that it's because the player is not winamp but Internet Explorer.
    It's an IE object in fact.
    Code:
    $oIE = _IECreate ( $_YoutubeSearch, 0, 0, 1 )
    Is it possible to configure RR for that ?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Is your webradio an Internet Explorer Link that you're opening? If so, you'll need to find a visu plugin that uses the level from the soundcard output... there are only a few that do that, most of the visu plugins for winamp take the audio output of winamp alone for the visualizations.
    Ride Runner RR's Myspace
    May 2008
    Bordeaux, France
    Smile
    Do you know some winamp's plugin that accept that ?
    If i understand , it's a winamp issu ? I use often the DFx4 AVS plugin . Is it possible to modified it ?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I know there was one called G-Force that did that, but seems to be paid software now.
    This can probably be done using the line-in plugin and selecting "what u hear" as source of recording on the sound card -- but it may get complex if you have an audio input in the line in already (i.e. Sirius, etc).
    May 2008
    Bordeaux, France
    Quote Originally Posted by guino View Post
    line-in plugin ? where i found that ?
    May 2008
    Bordeaux, France
    Smile
    Ok, i understand, you speak about the 'line-input' winamp plugin !
    I have installed the 1.8 version.
    Do i set something into winamp to use it or i must just to install it !
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I wonder what the setting should be in windows 7. There is not a what-u-hear option there.
  1. VISU and Winamp versions
    By spamminator in forum RR Skins
    Last Post: 08-08-2010, 06:45 PM
  2. Replies: 3
    Last Post: 11-23-2006, 11:14 AM
  3. Embedded Winamp visu plugin ?
    By iRover in forum Road Runner
    Last Post: 10-20-2006, 11:50 AM
  4. Winamp - Disable Visu on Startup ? Where..
    By kolemieux in forum Road Runner
    Last Post: 10-03-2006, 08:12 PM
  5. Winamp IBusComM.ini settings finally working
    By intense in forum Software & Software Development
    Last Post: 08-23-2005, 01:07 AM
