Results 11 to 20 of 22
Thread: Embeded Pc navigator 10
  1. #11
    Mar 2010
    Quote Originally Posted by pierrotm777 View Post
    Create a Navigator.skin and try that:
    Code:
    "Load;Navigator.skin;Navigator;C:\Program Files\Navigator10_FREE\PC_Navigator\PC_Navigator.exe --window_border=no --window_position=0,51,800,356;!BarneyMainWndCls!Navigator"
    still no luck..
    Skin file:
    RoadRunner Skin
    RRScreen navigator
    external_gps_off.png,external_gps_off.png,external _gps_off.png,external_gps_off.png
    C,0,51,800,429
    END
    Buttom from mainmenu:
    B,310,333,182,149,"Load;navigator.skin;Navigator;C :\Programmer\Navigator10_FREE\PC_Navigator\PC_Navi gator.exe --window_border=no --window_position=0,51,800,429;!BarneyMainWndCls!Nav igator",
  2. #12
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    no forget all that for the moment , lets just get it working the correct way , before makeing things a bit more complictaed ....
    add to your skin file
    A,0,51,800,356,
    then try , remove the this line for now
    "Load;Navigator.skin;Navigator;C:\Program Files\Navigator10_FREE\PC_Navigator\PC_Navigator.e xe --window_border=no --window_position=0,51,800,356;!BarneyMainWndCls!Nav igator"
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #13
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok really simple Spoon feed
    rrconfig
    select external in GPS Mode
    gpspath=C:\Programmer\Navigator10_FREE\PC_Navigato r\PC_Navigator.exe | --window_border=no --window_position=0,51,800,356
    gpsname=!BarneyMainWndCls!Navigator
    external_gps.skin
    RoadRunner Skin
    RRScreen external_gps
    A,0,51,800,356,
    C,0,51,800,356,
    END
    Menu Button
    GPS
    Nothing more , nothing else needed , unless you want to run more GPS app's
  4. #14
    Mar 2010
    Nice... now everything is working... i am learning every day
    Thx for the help...
  5. #15
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    because Nav10 is not truly embeded , at this point , when you press any rr button on the screen where the navi screen is , rr takes focus , and you lose nav10 , hence the "C" line this is a clipping area, basically cuts a hole in your skin file , so Nav10 can always be seen ....
  6. #16
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    this is a nice app, tcp/ip functions, and above all, is free. here's how i was able to embed it,.
    Code:
    SetTopMost;RR;True||Run;C:\Program Files\Navigator10_FREE\PC_Navigator\PC_Navigator.exe| --window_border=yes --window_position=100,100,480,272 --nohires||Load;External_gps.skin||Run;;Navigator
    what this code does is, makes RR TOP MOST, then opens navigator, then loads external_gps.skin, then embeds navigator. using --window_border=yes, makes navigator use a window name, and RR can find it.
  7. #17
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    lol cheers El , was about to start to look at this again tonight , but you on day shift beat me to it lol.....,,,,,
  8. #18
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Cool,
    But for me , when navigator is launched after RR, it stay on the taskbar and i need to click on the icon !
    And if i click on a button (by example 'play'), navigator stay hidden !
    this is my code:
    Code:
    "SetTopMost;RR;True||Run;D:\Program Files\Navigator10_FREE\PC_Navigator\PC_Navigator.exe |--window_border=no --window_position=0,76,800,466 --nohires||Load;navigator.skin||Run;;!BarneyMainWndCls!Navigator"
  9. #19
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    if you look at El's code the window_border is set to YES not NO, also change your window name at the end
    SetTopMost;RR;True||Run;C:\Program Files\Navigator10_FREE\PC_Navigator\PC_Navigator.e xe| --window_border=yes --window_position=100,100,480,272 --nohires||Load;External_gps.skin||Run;;Navigator
  10. #20
    May 2008
    Bordeaux, France
    Smile Mute RR option for Navigator
    As Sygic, GMPC or Igo8, you can use the Mute option when Navigator speak !
    Just follow the readme file instructions !
    Attached Files Attached Files
