Hi all
Hope someone could help me embeded PC navigator 10,
Because when i launch the program it self, the program open in the correct position and size, but when i go to my external_gps.skin in RR It opens fullscreen...
/Martin
Printable View
Hi all
/Martin
Pc Napvivator Free
I try that NOW !
jep pc Navigator 10 free :)
How do you change the size from full screen to 800x600 by example ?
If you right click the Pc navigator icon and choose properties, then under destination you insert this bit after PC_Navigator.exe --window_border=no --window_position=0,53,800,427
Example
__________________________________________________ _________________________
C:\Programmer\Navigator10_FREE\PC_Navigator\PC_Nav igator.exe --window_border=no --window_position=0,53,800,600
window_position=Xpos,Ypos,Width,Height
/Martin
Ok ,
I have tried that without success into the icon found on my desktop !
I have tried also to create a .bat without success !Code:"D:\Program Files\Navigator10_FREE\PC_Navigator\PC_Navigator.exe --window_border=no --window_position=0,53,800,600"
This is as close as i can get it at the moment
in rr.ini
GPS Path
You still need to set your --window_position=
window name
!BarneyMainWndCls!Navigator
in your gps skin file , copy your "A,xx,xx,xx,xx" and change to "C,xx,xx,xx,xx"
http://i446.photobucket.com/albums/q...uter1/navi.jpg
Well now i have tried that and the only thing i get is, my topbar, and bottom bar and nothing where the Navigator should be..
My skin file:
RoadRunner Skin
RRScreen external_gps
external_gps_off.png,external_gps_off.png,external _gps_off.png,external_gps_off.png
C,0,51,800,356,
END
And my gps Settings in RR.ini:
[GPS]
gpsmode=2
mapmonkeypath=Click here to set path
gpspath=C:\Programmer\Navigator10_FREE\PC_Navigato r\PC_Navigator.exe --window_border=no --window_position=0,51,800,356
gpsname=!BarneyMainWndCls!Navigator
overspeed=55
gpsport=0
mappointmap=1
mapcountry=United States
mapcity=
mapautozoom=true
isunits=true
usegpsserv=false
gasfinderautorefresh=false
you need this as well
A,0,51,800,356,
