Results 1 to 10 of 13
Thread: faking rrscreen
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    faking rrscreen
    i have a few plugins that call certian skin files for them to work .
    but these plugin popup skins , don't go with the way i have skinned Genesis..
    so i was hoping to catch the cmd , and fake the rrscreen value , so the plugin thinks its on the correct screen
    hope i have not made this to confuseing
    Thank you
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    you can catch most commands in a plugin, and change what it does.
    I think that includes load and menu commands
    I have done that with RRACCess control, which at the moment just blocks all commands and saves them to end once a successful keycode is entered.
    But to then fool another plugin, well it depends on whether it actually checks to see if it is on the correct skin.
    Some functions in my plugins do need to check this, others don't.
    What plugins and screens are you having a problem with?
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    you are going to hate me its your PI's lol
    as i have no others installed yet , but i know i will come across this again with others
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    LOL.LOL> Sorry Mate , just wanted to work around , for it , as i know not only your PI's do the same , its just that yours are the 1st ......
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Let me know what ones and what scenarios and what you would rather happen and I'll see what I can do.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    the only 1 i think can work is range in fuel ,,, fuel select you have as a list now ,
    i don't use these types of popups now , i use a form of switch button /label
    but i don't want you to change your code, defeats the object ,,,
    uk only use's the range buttons , but i assume your reading the fuelpricesrangemenu.skin , for those cmds to work
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by carputer1 View Post
    Nope, those button commands can be sent from any screen.
    The reason that one is different is because the UK one HAS to be one of those 4 values. Anything else and it won't work.
    I can change the UK one to send a command rrfp_ukrange instead of just loading the fuelpricesrangemenu.skin and you should be able to intercept that via the exectbl.ini.
    What were you planning of having instead of the buttoned menu?
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    arh any screen well that solves my problem there , its when the butons on the button menu , are assigned to the rrsreen to work , but this is not the case here now for fuel , i just assumed from your cmds as it was titled "Range Select Screen" , they were assigned ...
    no don't change cmd's others may want it that way ,,,
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well I can put the command in and it won't make any difference to anyone else as I can interpret that command in the plugin and do what I do already.
    No hassle for me if you want it.
    The only thing that happens if range5 etc button commands are sent from the fuelpricesrangemenu.skin is that an exit command gets added to the newrange command so that it exits that menu.
  1. RRSCREEN label code
    By Jebus in forum Software & Software Development
    Last Post: 11-08-2009, 11:07 PM
  2. Faking a monitor connection
    By dos4who? in forum LCD/Display
    Last Post: 11-09-2001, 02:20 PM
