Results 1 to 10 of 16
Thread: Vertical line using transparent pop ups
    Newbie bolloc's Avatar
    Jan 2011
    Ontario. Canada
    When the pop up window appears I have a vertical pink line showing to the left, I have made sure the image widths of the layers are all the same, and that there are no residual pixels in any images.
    Any idea what is causing this? Or better yet how do I get rid of it?
    Tia.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1-make sure you're using a BMP file (so compression doesn't change the color of the pixels)
    2-if you're resizing the skin, try using the original resolution of the skin to see if it still happens.
    Let me know your results.
    Ride Runner RR's Myspace
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    If it's a jpg the compression will take slightly off pink.
    Jan 2011
    Ontario. Canada
    The background image is a jpeg, the layers of the menu displayed in the background are .png's and the pop up layers are all .bmp.
    Resizing the skin just isn't doable at all, I loose all transparency when i do that, so the skin is created in 800x600 and displayed at that resolution. The pop up is 540 x 293.
    Thanks....
    ---------- Post added at 06:53 PM ---------- Previous post was at 06:51 PM ----------
    Just tested it without the background, problem still exists, so we can rule that out...
    Jan 2011
    Ontario. Canada
    Any other thoughts on this?
    Jan 2011
    Ontario. Canada
    thanks ...
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    The image you posted is dithered, and not a solid pink. That is why it looks purple instead of pink when it is zoomed out. Make sure the pink is color #FF00FF, and fill it, solid, in that color.
    Here is a screen cap of the image you posted, zoomed in:
    My Fiero Build Thread
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Give this image a try, it is not perfect, as you will need the original layers to make a nice clean image. I painted the best I could with the correct color, but again, its not perfect due to the dithering.
    It is good enough to test though to see if this fixes the problem.
    Jan 2011
    Ontario. Canada
    That is better, now there are a couple of lines only where the black intersects the pink. Easily fixable, now that you have identified the problem, thank you!!
  1. Best Vertical Front End
    By obstacleman in forum Software & Software Development
    Last Post: 07-23-2010, 02:24 PM
  2. Fixed: Lilliput EBY701 - vertical line across LCD
    By geirab in forum LCD/Display
    Last Post: 10-30-2009, 06:13 AM
  3. Im geting black vertical line - FAQ
    By mjo151 in forum Road Runner
    Last Post: 03-10-2009, 12:08 PM
  4. Vertical bar
    By RonS in forum FB Software
    Last Post: 08-17-2008, 01:22 PM
  5. Vertical CD-ROM?
    By NEO_0690 in forum Newbie
    Last Post: 11-01-2003, 03:58 AM
