Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: The embbed program cannot start
    Aug 2006
    Hong Kong
    Hi all,
    I try to do a Zeitornix Datalogger skin, but I am a beginner, so I make a simple one, just create a skin and launch the program into skin.
    However, the skin file is shown but the application didn't launch, could you know what mistake I have.
    The skin result
    my zeitronix skin file
    RideRunner Skin
    RRScreen zeitronix
    INC,Bottomtext.txt
    IMG,87,18,250,38,"Zeitronix.png",out
    B,11,9,75,52,"MINIMIZE",
    B,674,9,118,52,"ESC",
    L,346,23,220,27,255,255,255,18,"Arial:B","TRACKNAM E","SCROLLCENTER",,"DS=2,2,0,0,0"
    I,624,9,47,53,"PHONE_CONNECTED_PHOCO"
    I,578,12,44,45,"ONLINE"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    A01,0,73,802,471,
    C01,0,73,802,471,
    /, Y, Back Slider file path
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    END
    Use Winspector to capture the classname of Zeitronix Data Logger is "AfxFrameOrView90su"
    Update the ExecTBL.ini file
    "SetAppLabels","SETVAR;ButtonLabel;=MUSIC<<=RADIO< <=VIDEO<<=DVD<<=XM RADIO<<=SIRIUS<<=PHONE<<=WEATHER<<=PICTURES<<=BROW SER<<=PLUGIN MGR<<=DIMMER<<=CAMERA<<=MAPPOINT<<=GARMIN<<=iGO<<= iGUIDANCE<<=LAUNCH<<=DVB<<=MJS LED<<=MJS IO<<=WEB RADIO<<=ZEITRONIX<<=UnUsed<<=UnUsed<<=UnUsed<<=UnU sed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<< =UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUsed<<=UnUs ed<<=UnUsed<<=UnUsed<<=UnUsed"
    "MyApp23","LOAD;ZEITRONIX.skin;C:\Program Files\Zeitronix\Zeitronix Data Logger v3.1.5\zdl.exe;!AfxFrameOrView90su"
    "SetCommandLabels23","SETVAR;MyApp23LB;ZEITRONIX|| SetCommandLabels24"
    I enable the debug mode, the log file shown that command is executed.
    2011/11/29 下午 05:28:12: Que Exec: True, menu2.skin, "MyApp23", False
    2011/11/29 下午 05:28:12: EXECTBL Translation: MyApp23 -> LOAD;ZEITRONIX.skin;C:\Program Files\Zeitronix\Zeitronix Data Logger v3.1.5\zdl.exe;!AfxFrameOrView90su
    2011/11/29 下午 05:28:12: Executing: LOAD;ZEITRONIX.skin;C:\Program Files\Zeitronix\Zeitronix Data Logger v3.1.5\zdl.exe;!AfxFrameOrView90su
    2011/11/29 下午 05:28:12: Shell: "!AfxFrameOrView90su"
    2011/11/29 下午 05:28:12: Que Exec: True, zeitronix.skin, "ONSCREENCHANGE", False
    2011/11/29 下午 05:28:12: Leave Exec: False, zeitronix.skin, ONSCREENCHANGE, False
    2011/11/29 下午 05:31:19: Enter Exec: False, zeitronix.skin, , False
    2011/11/29 下午 05:31:19: Que Exec: True, zeitronix.skin, "OFFLINE", False
    2011/11/29 下午 05:31:19: Leave Exec: False, zeitronix.skin, OFFLINE, False
    Last edited by WolfSkin; 11-29-2011 at 04:52 AM. Reason: attached image cannot show
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Try like this...
    "MyApp23","LOAD;ZEITRONIX.skin;;C:\Program Files\Zeitronix\Zeitronix Data Logger v3.1.5\zdl.exe;!AfxFrameOrView90su"
    Aug 2006
    Hong Kong
    Thank you very much. I am missing one semicolon between skin and program.
    The program can launch now, but still not embbed, do you know why? I run both winspector and FindWindowInfo, they shown that the class name is "AfxFrameOrView90su".
    Moreover, how can I close the embbed program after press the "BACK" button. Thank you very much
    Feb 2009
    Finland
    If program doesn't embbed then window name is incorrect. Perhaps someone wiser can help you with window name.
    You can close embbed program with button command CLOSE.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Just use Zeitronix as the window name or you could try the whole 'untitled - Zeitronix Data logger v3.1.5' but just something unique in the title line is enough, hence 'Zeitronix'
    Aug 2006
    Hong Kong
    Quote Originally Posted by Dartman_71 View Post
    Thank you very much. After I fixed the embbed issue by Dartman_71, the default command of ESC will close the program automatically.
    Aug 2006
    Hong Kong
    Quote Originally Posted by Enforcer View Post
    Thanks, It can embbed, now I use "Zeitronix Data Logger".
    Aug 2006
    Hong Kong
    I am sorry that I had new question now.
    I want the Zeitronix Data Logger start when the RR is start, and close it when the RR is closed (like Winamp). I try to add the Windows Title "Zeitronix Data Logger" into General -> Embedded Apps and select "Close Embedded Applications When RR Exits" in RRConfig, but the program will not auto start.
    Moreover, after I entry the skin and back to main skin, the program will be clsoe automatically, how can I keep the program run when back? I currently use "ESC" for the BACK button, I searched Skin Command.txt but still not find related command.
    I am sorry for my poor english, if you want to screen dump, please let me know, I will dump the related screen for your reference. Thanks!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    To start the program when RR starts, look in RRConfig General-->Page 2-->StartCommand
    put
    run;C:\Program Files\Zeitronix\Zeitronix Data Logger v3.1.5\zdl.exe
    Use EXIT instead of ESC for the back button
    Aug 2006
    Hong Kong
    Thanks!
    The program can start when the RR is running, but the program show in front of the RR.
    Moreover, I change the back button from "ESC" to "EXIT", but the program still close after back. I check with Skin Commands.txt, it said the ESC is same as CANCEL or EXIT, and CANCEL is sames as EXIT. I also change the command to "CANCEL", the result is same.
  1. Start Program Automatically w/ RR
    By bratnetwork in forum Road Runner
    Last Post: 11-14-2008, 05:07 PM
  2. Best way to embbed DVD
    By qleyo in forum RR Skins
    Last Post: 09-24-2005, 07:57 PM
  3. How to embbed any Application in RR ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 01:35 PM
  4. Program won’t start…. Help me please…
    By Jagger in forum MediaCar
    Last Post: 02-17-2005, 09:01 PM
  5. How do i start a program when windows starts its shutdown rutines
    By darkwingduck in forum General Hardware Discussion
    Last Post: 12-10-1999, 07:28 AM
