Results 1 to 9 of 9
Thread: Help with DFX 5.1 music browsing?
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    I recently installed DFX 5.1 and had it scan my entire music collection (3,000 +). I was playing around with it wondering what to expect and ran into a few problems:
    - It only scanned 1,888 songs.
    - Some folders have songs and more folders, it only displays the folders when I click on them and not the songs when I open a folder.
    - Where is the button to play (open) a song when I click on it in the left song list menu? The play button at the bottom just pauses and resumes the current song playing. (Double clicking on it works, but that's not an option when in the car.)
    Is there a way to get a simple folder/directory interface with play/pause buttons like Winamp? I have my music organized into a folder structure where all songs by a certain artist is in one folder, then another artist is in another folder, then one folder has a lot of different artists.
    Also, is it possible to list shortcuts in the song menu?
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
    May 2008
    Bend, OR
    +1 is this possible? I'm having issues with media and songs displaying in dfx. I had to add them to a playlist before they would display.
    MySQL Error
    Oct 2004
    for simple folder based music, dont use rrmedia... use the normal browse... i think u press and hold a button, and it asks you which one you want to use...
    i dont use dfx5 enough to tell you exactly what button, but my guess the one named "browse"
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2008
    Bend, OR
    even in classic view it seems to want everything in a playlist first. Is there some trick to getting the ID3 tags formatted properly? I updated a few clean ones to test and they still won't display correctly in carwings or dfx.
    kdl
    kdl is offline
    Mar 2012
    Ive been having a LOT of trouble getting that DB to work correctly. For whatever reason it hangs on the "Querying Database.." and no information ever appears. This error does not happen however on my desktop. So many because my Netbook is underpowered? IDk. It never populates even if I let it sit for hours
    May 2008
    Bend, OR
    Quote Originally Posted by kdl View Post
    Did you grab the update on the second post of the dfx thread?
    Feb 2006
    Quote Originally Posted by steven765 View Post
    There are several ID3 tag editing programs out there, but my two personal favorites are MusicBrainz Picard and MP3Tag. MusicBrainz Picard has its own database which references the song whose tags your editing to the appropriate information. It's not perfect, but it's very handy when you have over 1,000 songs in need of cleaning up.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    It should run fine on your Netbook, I didn't have any issues when I was running it under my orig setup (VIA 1ghz). What were you doing up to the querying statement?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    May 2008
    Bend, OR
    Quote Originally Posted by stonestatue View Post
    haha I found the problem, RR has to be configured to actually use Id3 tags. No idea why it isn't default, the winamp auto tag function has a much better track record for me than picard, it only missed 100 out of 2800 songs. It was just the time to inspect each and every one to make sure it was correct that was insanely time consuming. I used tag&rename to manually clean up mass numbers easily, like setting the genera to hundreds at once.
  1. Removing album name when browsing music?
    By Slider1385 in forum Road Runner
    Last Post: 03-21-2010, 12:26 AM
  2. Music Browsing feature request
    By crimsonaudio in forum CarFrontEnd
    Last Post: 03-06-2008, 09:25 PM
  3. Problem browsing for Music in RR?
    By forrestang in forum Road Runner
    Last Post: 11-09-2007, 07:12 PM
  4. Slow Music Browsing, Reaction to buttons
    By kevinv2u in forum Road Runner
    Last Post: 08-03-2007, 04:24 AM
