Results 1 to 2 of 2
Thread: How to display the status of the GPS?
    May 2012
    How to display the status of the GPS?As the status of Bluetooth!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You'll have to edit/create a skin which can display the GPS information or use a skin which already has a screen that displays the GPS information, then you just need to configure the GPS port in the config or rr.ini - however keep in mind that if you're using a nav application without splitting the serial port RR will not be able to display the information as the gps will be in use by the nav application. You could use XPort to split the port in that case (
    As for bluetooth, the only current solution is the .net bluetooth mobilephone plugin (
    Ride Runner RR's Myspace
  1. Display the Status of a Custom Indicator as Text?
    By drewbp in forum Road Runner
    Last Post: 07-23-2012, 01:04 PM
  2. Replies: 0
    Last Post: 07-04-2005, 01:33 AM
  3. v1.31 status
    By FunkDaMonkMan in forum Bruno Speech Recognition
    Last Post: 05-22-2005, 11:40 PM
  4. Status...
    By guino in forum Road Runner
    Last Post: 03-04-2005, 07:46 PM
  5. Control things and display status of things
    By All4Norway in forum General Hardware Discussion
    Last Post: 07-18-2002, 01:32 PM
