i gave you the code....
EXAMPLE:
B,000,050,200,050,"RUNQ;SartMenu.exe",""
its just, RUNQ command
RUNQ;pathtoexe.exe
this startmenu.exe works great....but what command do i give the button to run it. It works as a menu option selction( the instructions to add menu buttons was perfect....but i want to run it from the windows button at the bottom of the skin window....so far nothing works.....help!!!!
Linux(Learning the curve...Like when driving!!!)
Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
EXAMPLE:
RUNQ;pathtoexe.exe
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
This is how I entered the command in the button command box...
B,000,050,200,050,"RUNQ;C:\Program Files\RideRunner\Skins\eLite 2 (Default)\StartMenu.exe",""
Did not work...so then I tried.....
B,000,050,200,050,"RUNQ;C:\Program Files\RideRunner\Skins\eLite 2 (Default)\StartMenu\Startmenu.exe",""
Still did not work...then I tried.....
Did not work..then I tried.....
"RUNQ;C:\Program Files\RideRunner\Skins\eLite 2 (Default)\Startmenu.exe",""
Did not work...so my question is...how do I enter it so it will work??? I changed the elite 2 skin name to elite 2 (Default)...and I'm using the start menu exe program you created mitchjs and saved it to my skin folder...and it work great, so for now I am using it as a menu button selection till I solve my current issue....just to be sure you are not confused...thanks
Here is my Startmenu icon in case someone needs it![]()
You can replace RUNQ by RUN ?
I gave up and instead created a new menu selection screen for my windows desktop stuff
All of my other screens have 'Windows' instead of 'Power' and open up my Windows Options screen except the 'Shutdown" screen...which has "Back To Main" instead of "Power', which returns me to the 'Welcome" screen...and the "Windows Options" screen is the only one that leads to the "Power" screen
I would...however....like to add level meters to the "welcome" screen(circled in white). How would i do that? I have not seen any skins that have level meters to use to edit from....thanks in advance![]()
I added visualizations to my "Welcome" screen. When the visualization is active it locks the welcome screen, but still leaves the control buttons at the bottom active....yayyy! To activate the visualization all I have to do is touch the screen....touching it again deactivates the visualization and unlocks the screen to use the menu screen buttons. I think that others will love how I I got the "Welcome" screen setup....and am submitting my skin so the the skin designer can tweak it for me since I still have other things to get working...such as weather, phone, and wifi....stay tuned![]()
I really like where this is going..........great job!
Thanks....here is a sneak preview of my WiFi screen. I hope the skin developer gets it working
Also here are the edited screens to line up with the labels too![]()
test your command in man's best friend SKINTOOL!
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
I have no idea how to use skintool....I'm still a novice to this skinning thing....but I will figure it out sooner or later!
