Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 86
Thread: New skin: Digital Graphite
  1. #41
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by hematec
    @guino:
    i'm just working on an implementation of Phoco and the Terratec Cinergy 600 in Roadrunner, so if i could help you anyway please let me know. but my VB programming-skills are still only basic
    hematec
    I'll not get to Phoco until I'm done with radio.. what exactly of the cunergy 600 are you implementing ? I'm planning to add D-Link and Radiator support in RR (Radiator supports the Cinergy 600 for radio). If you are/going to work on this, please just make sure to make separate modules (.bas) files for whatever you add (so we can mearge the code easily later). I also recommend to mark (say add a '*****PHOCO to everything you added/changed so we can merge the code later.. I make way too many changes all the time so chances are that when you're done, we'll have a hard time merging everything (IF we're not organized).
    Ride Runner RR's Myspace
  2. #42
    Feb 2005
    Holistic: Thanks, but I can't compare with you... I've a few good ideas and a little knowledge of graphics, no more. Keep doing that kind of skins, it's a good thing for RR.
    hematec: Thanks. We're open to all suggestions. When the first version will be ready, we want to ear the users' opinions and change wathever you want.
    Maybe someone could help him with the logo's and the flash, I wish I could, but I know i can't
    Don't worry Phythorian, we've a professional designer working on it.
    Be patient, lets do it slow and carefully.
  3. #43
    Mar 2005
    Germany
    @guino
    i'm trying to acces the radio card using the radio_io.dll provided by terratec.
    so i could use all the functions of this card such as rds. i've even heard that the rds decoder supports tmc and AF(alternativ frequency).
    basicly i'm trying to put everything in a .bas file and write the needed informations in public variables. but i've had to do some changes in the touchlist control to update the (->made the sub showlist public) to write for example the phonebook to a screen.
    the implementation of phoco is pretty easy through the phoco remote interface.
    all that is to be done is to send a xml string to phoco, informations are sent back also as a xml string.
    i think the most work has to be done by you by adding the controls to the modroadrunner.bas and of course by the skinners of you
  4. #44
    Feb 2005
    has he released the skin yet?
    andy
  5. #45
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @guino
    This sounds cool.. The showlist doesn't have to be a public sub because "centerlist" is public (and has the same effect).
    When you're done testing, send me what you've got and I'll definetely work on it..
  6. #46
    Constant Bitrate cyberlancer's Avatar
    Feb 2005
    Gallarate (VA) - Italy
    great
    a bit out of thread, i know, but please hematec keep on. there are a lot of Cinergy 600 users out there (without too much programming skills) that will be very happy if u can do what u're planning about this card!
  7. #47
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Quote Originally Posted by guino
    That is fairly simple to do but the image would either have to be a transparent GIF image Or I'd have to make something with a "mask" color do make transparent -- in which case JPEGs would probably not be very good for..
    How about PNG? It implements same range of compression like JPG, its optimal for high color images and it implemets the transparency correctly (unlike hacking JPGs)
  8. #48
    Feb 2005
    Yes, we've spoken about that previously, the problem is VB has not native support for PNGs, and there're a lot of more important things to do first. But I'd like to see Road Runner using PNG graphics too: transparency, good compression and better quality than JPGs.
  9. #49
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have honestly researched on this. I have yet to find a free and fast PNG control/class/module for VB. In any case, I do have ways of making tranaparent images (if I need to) with lossless formats (GIF/BMP). What I still don't understand the "need" of having anything transparent in RR. Give me a use for it and I'll think about it. The PNG compressing is nice all right, but with more compression more CPU/Speed issues arise as well. As they say in KY: "if it ain't broke, don't fix it!"
  10. #50
    Mar 2005
    front royal va
    Red face pink and black
    hi im new to the forum and was looking around and saw the digital graphite skin that you did and was wondering how hard it is to make it pink and black with a honda symbol?
    thanks
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. neocar skin workshop Alpha.2a [DOWNLOAD]
    By netsuo in forum NeoCar Media Center
    Last Post: 11-21-2004, 04:33 PM
  3. FRODOPLAYER 1.0.9 SKIN in progess
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-27-2004, 09:07 AM
  4. New Skin - Spaced_Out for FrodoPlayer 1.08
    Last Post: 10-17-2004, 09:50 PM
  5. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 08:10 PM
