Never mind I just download new version and every thing is working okoutahere outahere
Best Regards Hidroilio Perez
Printable View
my english is very bad !
http://www.kirikoo.net/images/7srita...219-052651.jpg
:)Quote:
Originally Posted by hidroela
@ srital6686:
have you seen this patch for ViaMichelin? I encourage you to download it.. makes the maps look alot better on a 7" monitor :) (plus other fixes to the program)
http://www.cybersuricate.com/web/MapStorePatch.aspx
Richard
What about a MapMonkey skin for the Alpine (Blue-S) 800x600 ??
Are you planning do make that ?? :-)
Yes, I have been so busy working on the Road Runner skins that I havn't got to that yet.Quote:
Originally Posted by henriktha
If you will make a .txt that gives details on setting this up, I will include this mod in the next release, and include your instructions in the read me.Quote:
Originally Posted by t0ffluss
BTW, there's no reason to make new images, if they are not different. You should just use: DESTINATOR_GPS_OFF.jpg,DESTINATOR_GPS_OFF.jpg,DEST INATOR_GPS_ON.jpg,DESTINATOR_GPS_down.jpg in your .skin file. You could also make a more obvious name for your .skin file, like VIAMICHELIN.skin.
Hi Moremods, i am using your alpine blue skin with phonco and when you check the contacts etc not all of the information is visible, Home phone number is visible but mobile number isnt i have also notice that the signal strength bar isnt working. i have checked it functions correctly with another skin. is anyone else having this issue?
Cheers.
i am using the RR -02-19
Rob.
Quote:
Originally Posted by more mods
Sure!, Ill see what I can cook up :P .. So what your saying, I can just rename the cfg and images to something like "Viamichelin_GPS_ON" and so on?
Richard
No, don't rename them or copy them. If you are using an existing image and it doesn't require any changes then you just need to edit your .skin file to use those images. In other words there's no point in having two identical images (in this case destinator_gps_off/on/down and external_gps_off/on/down) with different names. If your not changing the images destinator_gps_off/on/down, then in your skin file change:Quote:
toQuote:
MEDIACAR Skin
MEDIACAR Alpine"Destinator Skin
EXTERNAL_GPS_OFF.jpg,EXTERNAL_GPS_OFF.jpg,EXTERNAL _GPS_ON.jpg,EXTERNAL_GPS_down.jpg
Then name your .skin file Viamechelin.skinQuote:
MEDIACAR Skin
MEDIACAR Alpine "Viamechelin GPS" skin
This way both Destinator and Viamechelin use the same images, so your mod does't require the addition of any images.
As for the rest, I haven't seen how you have it configured, so I can't help you much.
