Page 6 of 31 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 303
Thread: Alpine
  1. #51
    Raw Wave
    Jun 2004
    On the beach
    Just open the .skin file in notepad and alter the fields as above.
  2. #52
    FLAC J187's Avatar
    Nov 2004
    Boston
    Thanks UK, I edited my post above. I figured it should have worked. Silly oversght
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  3. #53
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by DjBac
    Does playlist/file search work for anyone with this skin!!
    the latest RR supports it, but you have to change the code in the .skin files from ENTER to SEARCHLIST and SEARCHFILES respectively.
    Ride Runner RR's Myspace
  4. #54
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by guino
    Yup it works perfectly after the edit. I have found that I have to hit the browse button after each search to be able to search again, otherwise it just takes me to the list screen. I am loving RR more and more
    Please help.
  5. #55
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by J187
    You can solve this by either adding a "BACK" button on the search files skin (so you can get "out" of the search results) OR by making the search button have a code like "!BROWSE||SEARCHFILES" (which would cause it to ALWAYS search your entire music path).
  6. #56
    FLAC J187's Avatar
    Nov 2004
    Boston
    OK, 2 part question Guino.
    1. I noticed while looking at the Search_Browser.Skin file in the editor that the button for Search didn't have a "command" box. It has Ascii, Code and Tooltip. Why is this different from most buttons? What actually executes the code?
    2. You say put code in like "!BROWSE||SEARCHFILES", where would I put that exactly.
    3. How would I make it so that when you got search results and clicked on Select, it started playing the song and brought my right into the audio player screen rather than the list screen. Thanks for the help.
    Please help.
  7. #57
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That's 3 parts..
    1-Code is the same as command for buttons.
    2-Open The skin in the skin editor, select the search_browser skin in the menu, then double click the SEARCH button. Under CODE/Command set it to "!BROWSE||SEARCHFILES" (including quotes).
    3-From step 2, double click on the button that says "SELECT" and change the CODE/Command from "SELECT" to "!SELECT||MUSIC". You may want to do the same with the "SELECT+" button to "!SELECT+||MUSIC".
    If you want to change/make skins you should read Skin Commands.txt as it explains all of this.
  8. #58
    FLAC J187's Avatar
    Nov 2004
    Boston
    I know it was 3 parts, that was my lame humor.
    I know the skin commands explained how to implement things I read it a couple times, but I wasn't exactly sure where to put the changes. The Code thing threw me off, I was used to seeing the Command box and I didn't realize the code for the search button was 013 - just looked out of place from what I was used to. Thanks for the help though, very much appreciated.
    Please help.
  9. #59
    FLAC J187's Avatar
    Nov 2004
    Boston
    I got it working now Guino, thanks. ON this skin the command was actually "Audio" that was the thing that screwed me up the most. I got though, awesome. Now I can search one right after the other without hitting anything additional. And selecting a song from the Search results go right to the audio player. Right on!
    Please help.
  10. #60
    FLAC J187's Avatar
    Nov 2004
    Boston
    Guino, I though it was working but I guess its actually not. I am using a mute computer at work, so when I saw that I had returned to the Player screen after selecting a search result, I assumed it was playing. Not the case however, When I change "Select" to "!SELECT||MUSIC", which for me I guess is actually "!SELECT||AUDIO" and then search, get results and highlight a result and hit select it just returns to the audio_player screen but doesn't play the selection. It doesn't que the selection either. What could be the problem?
    P.S I'll start a new thread asking my question as well, perhaps I won't have to keep bothering only you. But if you can help and do respond here, thanks again.
    Please help.
  1. Alpine AiNet aux input adapter SOLUTION!!!
    By aydensdad in forum General Hardware Discussion
    Last Post: 08-16-2011, 06:30 AM
  2. Alpine Ai-Net to RS232 interface.
    By spaintra in forum General Hardware Discussion
    Last Post: 09-09-2010, 01:38 AM
  3. Problems with Alpine skin
    By chuckster in forum Road Runner
    Last Post: 01-27-2005, 11:22 PM
  4. Integrate mp3 player w/ Alpine FM modulator ?
    By L0C0 in forum General Hardware Discussion
    Last Post: 03-04-2004, 01:45 AM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
