Page 17 of 61 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 602
Thread: Flash/Spinning Logos (By Many Users)
  1. #161
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    Quote Originally Posted by t0ffluss
    I love the animated logo's you've made!!! thanks for all your work!
    I have one problem though...
    Is there a fix for this issue? .. the swf file interferes with the buttons in the main window.. as you can se in this example screenshot I took..
    regards
    Richard1
    Probably it's dued to an interference of the sensible areas of the flash animation and the radio button. Try using the skin editor to reduce the dimension of the buttons
    See my car and donate for spinning logos at www.ildena.it/carpc
  2. #162
    Jun 2002
    Norway
    Quote Originally Posted by ildena
    thx for fast reply!
    hmm.. well its not ONLY the radio button, its on every button.. Its just that the radio button was the last button that was highlighted before I took the screenshot..
    I could make the flash smaler, but then It would become to small
    And the buttons could be smaller.. ill look into the fact that I can make the buttons smaller, I just thought maybe there would be somebody that had the same issue...
    Regards
    Richard
    "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
    Albert Einstein
  3. #163
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can use the CF skin code to "CUT" the flash object into a shape that allows the button areas not to be covered by the flash object.
    You'll probably need 4 cuts (for each edge) of your flash object.
    /, CF, X, Y, W, H
    CF1,000,000,100,100
    CF1,300,000,100,100
    CF1,300,400,100,100
    CF1,000,400,100,100
    (YES) they're all CF1 (one). The positions and sizes are relative to your FLASH OBJECT's size. so the first line cuts the top-left 100x100 corner of your flash object. Once the flash object is cut propperly, your buttons should behave propperly. You can use more than 4 cuts if that improves the area to be cut more precisely -- The areas specified above are MERGED together.
    Ride Runner RR's Myspace
  4. #164
    Jun 2002
    Norway
    Quote Originally Posted by guino
    /, CF, X, Y, W, H
    CF1,000,000,100,100
    CF1,300,000,100,100
    CF1,300,400,100,100
    CF1,000,400,100,100
    thx!
    excellent! Ill try It out tomorrow Ill let you know If It Works...
    Regards
    Richard
    Albert Einstein
  5. #165
    Mar 2005
    MG Logo Plase............ :-)
  6. #166
    Jun 2002
    Norway
    /, CF, X, Y, W, H
    CF1,000,000,100,100
    CF1,300,000,100,100
    CF1,300,400,100,100
    CF1,000,400,100,100
    Thx guino!
    It worked.. had to tweak the numbers, but it worked!
    Thx !
    Richard
    Albert Einstein
  7. #167
    Dec 2004
    Italy
    Quote Originally Posted by steve80
    Io ho una MX-5 e come ben sai Mazda-MG un po' come Pisa-Livorno, Roma-Lazio, Milan-Inter... ma dato che sono un buono l'ho fatto ugualmente...
    Here it is...
    Attached Files Attached Files
  8. #168
    Any chance of a Smart "chicked head" logo (www.thesmart.co.uk)
  9. #169
    Dec 2004
    Italy
    Quote Originally Posted by smartroad
    Here...
  10. #170
    Here...
    Cool! Thanks
  1. Help needed w/ flash logos
    By titubatu in forum Road Runner
    Last Post: 12-11-2006, 12:29 PM
  2. Need some logos
    By Gobby in forum General MP3Car Discussion
    Last Post: 03-24-2005, 06:32 AM
  3. All EPIA Board Users READ!! (Boot Logos)
    By PCF_Ronin in forum Software & Software Development
    Last Post: 01-29-2004, 04:45 PM
  4. EPIA Full screen boot logos...
    By Defiler in forum Software & Software Development
    Last Post: 12-07-2002, 01:54 AM
