Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 54
Thread: alumined metal is back
  1. #21
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    Quote Originally Posted by ildena
    New gps window...
    i like it i think it looks nice good work
    [|||||-----] 95% complete
  2. #22
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Sure...
    www.chellietintori.it/dmm.zip
    P.S. Lower buttons are MM's ones because I had no time to make a menu skin for MM... Infact it's not possible to use a function "menu" that calles the menu of MM... so... why don't use MM buttons?
    I know that's a bummer there's no "menu" function. What they have instead is a function for each option INSIDE the menu. So basically (if you wanted) you could make a .skin menu, load it with the dynamic menu command from RR and have the options in the menu (to do the same that MM's menu does). The menu could even look the same as MM's for all I know.
    Ride Runner RR's Myspace
  3. #23
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by aguila
    what information from MM can be iuncluded in the RR skin, like ETA and so. How do you do this?
    Look at the Skin Commands.txt file from RR. Theres an explanation about that there..
  4. #24
    Variable Bitrate aguila's Avatar
    Jun 2004
    the Netherlands
    Quote Originally Posted by guino
    wow this info was there all the time, I simply did not look. Shows again how complete and user-friendly your software is!! thanks a lot for the super service
    MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
    http://www.mp3car.com/vbulletin/show-off-your-project/31991-audi-tt.html
  5. #25
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    Are you adding to this skin?
    Ildena,
    Are you going to add to this skin, or is that it? I have it installed in my Car and love it.
    I'd like to play with the Destinator skin buttons to customise it. Remove some of the left button and add some different one, like navigate to Favorites, etc.
    Could you send me the PSD for DESTINATOR_GPS_DOWN & DESTINATOR_GPS_UP?
    If I change anything I'll release a copy of it on this thread. I'd also like to integrate some of MM v1.1.348 features into the skin.
    Cheers!
    -Ruairi
    Email: ruairi @ rutlands . com
  6. #26
    Jun 2004
    the Netherlands
    Quote Originally Posted by ruairi
    Ildena,
    Cheers!
    -Ruairi
    I would like to have the psd files as well if possible?
    http://www.mp3car.com/vbulletin/showthread.php?t=31991
  7. #27
    Newbie poseur's Avatar
    Mar 2005
    Yakima, WA, USA
    updates?
    Hey I've been building my carputer and hoping this skin would progress so I could load it up and have it my first-run in the car. Is there any newer version than the sample available yet?
    Amd 2200+ athXPmobile, MSI KT6V-LSR mobo, Opus 150w, 512 ram, exterasys WIFI card, Hitachi 160gb, 3.5"hdd, bluetooth, Xenarc 700ts
    4/9/04: case roughed out and functional, hardware all together, finishing up bezel for screen, layingout wires, etc in car.
  8. #28
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    Quote Originally Posted by poseur
    Just ready... I'm waiting for two or three updates I asked to Guino and then I'll finally "release"...
    See my car and donate for spinning logos at www.ildena.it/carpc
  9. #29
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ummm... can you refresh my mind ? I'm in the middle of some major updates, so I could probably "squeeze" it in right now..
  10. #30
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    it is possible to call all functions of MM with the latest patch's hotkey_cmds...
    even add cam, call menu, etc
  1. Replies: 4
    Last Post: 03-23-2005, 10:33 AM
  2. How to get to back of headunit
    By nick8197 in forum Newbie
    Last Post: 02-11-2005, 11:55 AM
  3. Replies: 5
    Last Post: 01-03-2005, 08:39 PM
  4. Adding another monitor in back for kid.
    By biglips31 in forum LCD/Display
    Last Post: 11-20-2004, 06:17 PM
  5. Where can i find a lcd 20x4 with led back light
    By Dan in forum General Hardware Discussion
    Last Post: 04-28-2000, 12:14 PM
