Results 11 to 20 of 27
Thread: Preview Ipod Skin
  1. #11
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by guino
    Man, I can most definitely add the code above, but that seems like the kind of thing that would get Apps to freeze... I'll try it out with a few apps and if no problems, I'll leave it in... Thanks for the code BTW.
    Just looked at the code, and think the width and height should be -2 not -1.. but I guess u would of figured that out
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by CdRsKuLL
    Actually I'll probably use GetWindowRect first, then add 1 to left/top and remove 2 from right/bottom. I actually have a function that does similar but the oposite (to clip regions off inside).
    Ride Runner RR's Myspace
  3. #13
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @CdRsKuLL
    I've implemented this "border removal" thingy, give it a try and let me know what you think...
  4. #14
    Feb 2004
    Manchester
    yep can confirm its working 100% :-) thanks fella. I've just downloading the source and had a look, got it working no probs.. but really dont know where to start.. everything is commented.. fantastic work, found the bit of code you have added for me ;-)
    CdR
  5. #15
    Feb 2004
    Manchester
    ok been playing alittle more with freedrive, improved the loading time, and fixed a few things.. would it be possible for RR to be the parent of the screen its embedding ? Also noticed that when it embeds for the first time, sometimes the skin (RR's skin) needs to be refreshed as its all messed up. A simple click back to the prev menu and then back to the gps menu solves this..
    cheers
    CdR
  6. #16
    Feb 2004
    Manchester
    picture of the gps address input page.. its getting there now :-)
    CdR
  7. #17
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Amazing! Is this all functioning with freedrive?
    can you give a small overview of FreeDrive vs. MapMonkey?
    The only thing that I noticed that I likes was MapMonkey's speedtrap notification, will ou be impleneting this into FreeDrive?
  8. #18
    Feb 2004
    Manchester
    yeah the above shot is with freedrive.. If you go back about 3 months from the current monkeymap.. thats what freedrive is like :-) Although its is more skinnable, but you do loose lots of nice stuff, and its defo got more bugs than MM at the mo. As for speed cams.. Its getting there, not done any coding for a week or two, I have done a import speed cam button, but when its importing a file into its fav's folder, once it gets past 1000 speedcams it tend to slow down loads, so this wont be a working option really. I need to play alittle more..
    Picture of video
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    cheers
    CdR
    I've tried parenting a bunch of apps, and some simply crash (MM, some vis etc). I can most definitelly add a parenting function for FREEDRIVE specifically, if that won't crash it (like MM -- without using the SDK that is).
    This skin is looking awesome by the way!
  10. #20
    São Paulo, Brazil
    What exactly is parenting? what difference does it have from merely embedding?
  1. Skin preview sony cdxf7700
    By M^ck^y in forum FrodoPlayer
    Last Post: 03-04-2005, 08:04 AM
  2. Replies: 1
    Last Post: 02-20-2005, 09:10 PM
  3. Preview of my skin (almost done)
    By Konrad in forum FrodoPlayer
    Last Post: 11-01-2004, 06:31 PM
  4. Mediacar Radio Skin preview
    By coyote in forum MediaCar
    Last Post: 02-23-2004, 07:42 PM
  5. skin preview
    By liquid_smoke in forum ME Archive
    Last Post: 12-16-2003, 08:48 PM
