Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 59
Thread: flash skin preview
  1. #11
    Constant Bitrate holistic's Avatar
    Feb 2005
    Denmark
    well the button thingy is actually pretty complicated at first but as soon as u get the hang of it i becomes vey obviusly... it's kinda hard to explain but
    the page where i learn all my flash stuff from is:
    http://www.flashkit.com/tutorials/index.php
    is a really usefull site
    the reason it's hard to explain is that im still learning myself.. never done much flash.. only small things like website players etc..
    Food goes in here..... that's right ... mmmmm
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's a "sample" file with the brushmetal skin.. I've only learnt enough of flash to be able to do that.. you can use labels in flash and you can send commands from it.. to send commands you just need to run "fscommand("PLAY","")" for instance -- this is a script command in flash. RR will set variables in the flash script(s) for all labels you define in the .skin file (say TRACKNAME etc) how you read or display that variable from your scripts is up to you.. my sample file simply associates a dynamic text box with the variable and when RR sets the variable it gets displayed.
    I wish I knew more to help you with.. but I did just re-test the sample and it works..
    here's the bit of skin definitions that allows it to work:
    /, Flash Sample
    /, x y w h Movie
    F01,107,530,068,048,"SAMPLE.SWF"
    /, You MUST add labels for all information you intend to use in the flash movie (you don't have to show the labels)
    L20,000,000,000,000,000,000,000,08,"Arial","TRACKN AME", ""
    Ride Runner RR's Myspace
  3. #13
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    ok, been playing but not getting very far.. I have put a textbox and called it 'time' made it a target, and also set the text to dynamic. I have then entered the following code to the scene script..
    onLoad () {
    time.text = TIME;
    durrr sussed out DYNAMIC text now.. lol
    Now I would of thought this then would set the time text, and would show when its run.. hmm Guess not. I'm playing with swishmax at the mo, not got flash at the mo.
  4. #14
    Feb 2004
    Manchester
    ok.. managed to get the text to display the contents of the label. just need to suss out how to get it to check it and update if needed
    CdR
    just realised where all this is being posted.. sorry will start a new thread. didnt mean to hijack this one, and totally go off topic
  5. #15
    Feb 2005
    Denmark
    no prob.. we'll just rename it to the official flash thread
  6. #16
    Jan 2004
    NYC
    Here was one i was playing around with....using holistic skin
    Just uses alot of CPU power
    Attached Files Attached Files
  7. #17
    Feb 2005
    Denmark
    updated the teaser to the new skin im working on...
    http://www.hdesign1.dk/flash.php
    maximum cpu used is in the startup it tops at 65-70% when integrated in RR
    after that it stays at 0-8%
    pressing topbar makes it go up to about 40% and then down again to the 0-8%
  8. #18
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Are you planning on adding sound effects to this?
  9. #19
    Dec 2003
    Denmark
    hold da op - det rykker
    Quote Originally Posted by holistic
    damn it looks good - i am really looking forward to the release of this skin....
    Flash just makes the spot -
    Mazda 323F
    Via 800 Mhz
    256 mb ram,120 GB hard drive
    Lilleput touchscreen, D-link USB radio,
    Griffin Powermate,
    Itune PW 70a powersupply, ITPS
    Windows XP Pro, RoadRunner
    Haicom HI-202S, Simacar navigation from Simatech
  10. #20
    Variable Bitrate MC_Stoo's Avatar
    Jun 2004
    Manchester, UK
    Ooooh sexy
    DC UK Forum
  1. Preview Ipod Skin
    By CdRsKuLL in forum RR Skins
    Last Post: 03-11-2005, 06:34 PM
  2. Replies: 1
    Last Post: 02-20-2005, 09:10 PM
  3. Preview of my skin (almost done)
    By Konrad in forum FrodoPlayer
    Last Post: 11-01-2004, 06:31 PM
  4. Mediacar Radio Skin preview
    By coyote in forum MediaCar
    Last Post: 02-23-2004, 07:42 PM
  5. skin preview
    By liquid_smoke in forum ME Archive
    Last Post: 12-16-2003, 08:48 PM
