i think if command, "GPS", from a flash in main menu is sent to RR
it will do samething as GPS button does. so yes it will be embeded in gps window...
what i tried to decribe was...
make gps menu look like main menu and when you start RR
it will bring up main menu first with simple flash playing without repeat...
then at the end show, flash will send a "GPS" command
and RR swiches into GPS window
gps window looks just like main menu with gps window in middle instead of flash show in the box.
just a thought...
oh... when you clone main menu skin to gps menu skin
make sure you disable gps button in gps menu skin.
or replace it with some rotating flash which indicates gps is in use.![]()
Originally Posted by Dj_Aleks
LinkBack URL
About LinkBacks
