Results 1 to 10 of 12
Thread: GPS/TV in Menu
    May 2004
    Munich/Germany
    GPS/TV in Menu
    Does anyone know how to include GPS window in Menu skin?
    I want include it there where the black area is.
    Raw Wave RoyN's Avatar
    So Paulo, Brazil
    I dont know if you can embed the same app on 2 skins, I woudlnt think so, but you can try making the GPS skin your menu skin, and in the startup options in RRConfig you put "gps"... this however, would make you loose your fullscreen GPS, unless it is possible to do what I said in my first comment...
    Variable Bitrate aguila's Avatar
    Jun 2004
    the Netherlands
    Quote Originally Posted by xequtor
    I like the red LCD font. that will match very nice with the TT dash.
    MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
    http://www.mp3car.com/vbulletin/show-off-your-project/31991-audi-tt.html
    May 2004
    Munich/Germany
    Hier is what I mean, I remember gunio sad something like this will be/is supported.
    I don't want to make Menu skin GPS skin, also I want to make same with Video skin sort of preview window where you can clik on it will go to full screen.
    Gunio? say something!
    May 2004
    Munich/Germany
    Quote Originally Posted by aguila
    Yeha thas why I'm doing it, for TT or any other Audi with that sort of dash.
    Feb 2004
    YES!! Im longing for a nice Audi skin
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There are a few "special" skin files... Map Monkey is one of them... the others are Video_player, Radio, Launch and TV... You can most definitely make mapmonkey run embbeded in the main window, but RR will not pull off the information from MM if that's the case.. it will simply run it embbeded like any other application.. the definition is:
    A01,XXX,YYY,WWW,HHH,RED,GREEN,BLUE
    (Check skin commands.txt for details).
    Said the above, it doesn't prevent you from making a MM skin that has all the above functions you showed above.. you can most definitely add a start command such as "destinator" to go directly into the gps screen (above) but you will still need a menu.skin file to load first.. A suggestion would be to have it as the audio player (with your playlist etc) and you'd barely feel the screen changes when alternating from GPS to main window (check the BFM skin to know what I'm saying).
    Ride Runner RR's Myspace
    May 2004
    Munich/Germany
    What I want is just include MM (or any other GPS app) Screen and not the whole app, just want to show in menu.skin a map with my possition.
    If I can do it with MM Destinators thats optimal and if I have to use different app thats fine cuz I use GpsGate.
    So can I pipe the screen from Destinator to menu.skin and scale to like 500x300 without the functions like in GPS skin?
    If thats not posible can I run 2nd instance of Destinator in manu.skin?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    MM is embbeded directly INTO the DESTINATOR_GPS skin in RR. If you wish to, you can disable the interfacing with MM (in MM's settings.ini) and it will embbed it as a normal application. Once that's done, MM should embbed like any other application -- but this costs you the interfacing abilities of displaying and controlling MM from within RR..
    Now, when using any application embbeded like above, if you try to run it from multiple screens, it should show the same application embbeded -- without re-opening it, but re-using it's last intance as long as you don't close it (in which case it would restart when entering such screen). So you could for instance make MM run embbeded in the main menu by adding an Application window to menu.skin and then use the run command to run it in there.. if MM is already running it will simply place it in the new location on the new screen... you can run MM initially from the start command in RRConfig then the GPS will already have it loaded (or by any means you woudn't need a gps window...
    If you send me the skin files you have I can help you with the definitions.. but I am unclear of exactly what you want to do ...
    PS: The TV and video screen can also "look" like the same screen, but they will ONLY work if the skin files are named "video_player.skin" and "tv.skin"..
    Sep 2003
    LA, CA
    just an idea
    why don't you clone menu.skin to destinator_gps.skin + application part or GPS
    then enter a simple flash on th box area in menu.skin.
    may be welcome sign or whatever then send a "GPS" command at the end of flash (no repeat)
    then it will change to destinator_gps.skin which will exactly same look as main menu with all the buttons...
  1. Replies: 0
    Last Post: 02-20-2005, 01:03 PM
  2. Menu always on top, other new features
    By clean customs in forum FrodoPlayer
    Last Post: 01-22-2005, 05:27 PM
  3. skinning --> full screen menu
    By djScript in forum FrodoPlayer
    Last Post: 11-08-2004, 08:14 PM
  4. my menu button doesn't work on my skin
    By gambit32 in forum FrodoPlayer
    Last Post: 10-02-2004, 08:53 PM
  5. How to setup gps button in menu
    By Tyrael in forum Media Engine
    Last Post: 02-25-2004, 03:53 PM
