Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
Thread: Flash request please..
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by holistic
    damn u beat me to the coloured background
    Also forgot to mention something to you:
    If you use scrolling labels, they stay Over the flash objects, so that could be an option if they don't move/hide within the flash object (if you can't get the date from flash).
    Ride Runner RR's Myspace
  2. #12
    Jul 2004
    Tampa, FL
    Yea the best way would to be issue an fscommand with a repeat parameter have RR handle it and then when they "let up" issue one that tells it to stop repeating.
    '05 350Z Roadster
    http://www.gregburch.com/
  3. #13
    Jul 2004
    Tampa, FL
    You can easily make scrolling labels in flash by using the hscroll property of textfields, by the way.
    '05 350Z Roadster
  4. #14
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Check out www.flashkit.com - it's an excellent site with a lot of free audio samples too (gotta trawl though the crap though). Lot's of tutorials and code available too. Also check out www.flash-forums.co.uk - it's pretty good for Q & A's - the guys on there are really helpful. Just ask for what you want and they usually come up with a few different coding methods
  5. #15
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    thanks fella
    :-) bookedmarked
  6. #16
    Raw Wave
    Jun 2004
    On the beach
    Looks good CdrSkull :-)
  7. #17
    Feb 2004
    Manchester
    thanks.. sussed out the volume up / down repeats now so it goes up and down when you click and hold, as it does on a normal skin. I've also added two extra buttons for the skip through song action :-)
  8. #18
    Feb 2004
    Manchester
    ok, now i've finished the audio screens, its good the way you can just change the background and it gives the flash a whole new look. Gman I've sorted out the volume and search buttons. Would it be possible to asign the varables mute to on or off and same with the random / search.. that would be kewl as there the only thing missing :-)
  9. #19
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    one thing I noticed when I tested this out on my p3 700mhz laptop .. was that the transitions are slow.. and get choppy ..
    usually you can fix this by limiting the number of animating parts .. especially ones with alpha blends.. so .. instead of animating the volume and the playlist controls.. do one then the other.. and make the transitions shorter ..
    I know most people use a faster machine for thier carpc.. but I use a 900mhz athlon and I know it would be a bit chunky.. along with the via chip people too..
    it's pretty sweet though for just learning flash ..
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
  10. #20
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    that teaser is georgeous. actually, both of them.
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 07:23 PM
  2. 800mb Flash Drive as bootable drive
    By Tidder in forum General Hardware Discussion
    Last Post: 04-27-2005, 05:40 PM
  3. flash
    By holistic in forum Road Runner
    Last Post: 03-07-2005, 02:46 PM
  4. adding flash
    Last Post: 02-14-2005, 11:25 AM
  5. Compact Flash WIFI?
    By RedGTiVR6 in forum Wireless Communications
    Last Post: 12-30-2004, 04:17 PM
